So I have a conventional gas boiler and c/h system that’s in generally good repair and order. My hot water cylinder is leaking very slightly round a fitting, but the rest of the ports/fittings look a bit ropey with the putty looking very brittle. On the last boiler service the engineer suggested that the cylinder should be replaced. However, when the owner of the firm called, he said that if we were planning on staying in the house (we are) then we’d probably be better off upgrading to a new combi. His argument was that I don’t know what else will fail on the existing system in the next 1,2,3 years and that the new boiler would be more efficient and have a 12 year warranty.
So, a new cylinder fitted is £1000 (which I thought was a bit high), and a new combi fitted is £2,500.
My existing boiler was fitted in 2009, and has generally performed well. I had a flame sensor replaced on it, and I need to replace the 3 way valve myself as it’s sticking. Pipe work is good and tidy.
So, in people’s opinion would it be worth the extra money to upgrade to a combi, what are the real benefits?
thanks
More space
Never run out of hot water
Lower running costs (not because boiler is any more efficient than your current boiler unless current boiler is not of condensing type). Lower running costs because you only heat the water that you need when you need it.
Downsides could be:
Less reliable than standard boiler
Can't deliver high volumes of hot water in colder weather. This depends on boiler "power" and your expectations with respect to flow rate of hot water.
Removal of hot water tank sometimes = loss of warm airing cupboard.
Secondly the Combi wastes a LOT of water, at best 35sed, usually more of running the taps full bore until hot water comes out. All of that is high quality treated water going directly to waste ! If anyone has a solution to this, please let me know
We are looking at replacing our boiler with a combi as the run to the sink is enormously long (no thanks to my wife who had the kitchen replaced and didn't have the hot water re-routed). We also have a small bathroom with airing cupboard where we would put a shower (neither of us are in the 1st flush of youth) if we got a combi. It's all about balance and the compromises you are prepared to make.
Dont buy British boiler.
It may have to run awhile before it comes through hot but just put a little pump on it
I would never swap a good conventional system for a Combi because I like a lot of stored hot water and powerful shower pumps ....I don't care about a couple hundred quid savings in a year ;I want a proper shower .
It also depends how many bathrooms you have and the intensity of demand in short time frames.
Plumber is shitting you........210 insulated cylinder direct or indirect twin coil quick recovery is under £200
the carcass of the heating system will remain pretty much unchanged whether you swap boiler type or not
The only vulnerable parts are the motorised valves and possibly a few minor boiler parts.
Get a Magnaclean fitted if you don't have one
new cylinder ,if similar size ,should cost about £450 fitted plus immersion
A replacement hot water cylinder should do it and £1k is way too much!
By the time I recoup any efficiency savings from what any new boiler install costs, I’ll be in my grave, so I’m sticking with the one I have. The only limiting factor is spare parts.
Oh, and the wife said to pack my bags if I get rid of the hot water tank in the airing cupboard.
A cheap but decent combi (Vokera) is less than £500, with a warranty
I'd expect to get it fitted for £600-£700
I had one supplied and fitted to replace an existing combi recently:
Prior to that, I have bought 2 myself for less than £500, paid £500 to fit one as a replacement for a combi, and £600 for one to replace a stored water system like yours
I'd expect
you can get an accumulator storage vessel to store cold water at high pressure, I considered getting one in our last house
Eventually, we found out that a factory 2 miles away was breaking agreements and taking lots of water at the wrong times of day, the pressure increased after we complained
I'll correct my post
found this though, any use?
Increase Pressure to or from a Combination Boiler - Shower Power Booster
Worcester Greenstar Combi Boiler 30kw
£910 + VAT = £1092let's say £650 to fit: total £1742
I've bought Worcester Bosch for my house and the last one, and to be frank have had lots of problems, we had no hot water for 2 weeks once, since then we've had a permanent service/repair contract with Worcester, since the parts seem hard for other fitters to obtain. The current boiler is overspecced for this house, yet seems to need major replacement parts every year
Hence me taking the advice of gas fitters on my other houses, they recommend Vokera as a good cheap brand, there was another brand too, not sure. Vokera comes with 5 or 6 year warranty as standard
