*SOLD* Marshall AS100D Acoustic Guitar Amp
Circu5Circu5 Frets: 4
edited July 2021 in Amps £
*SOLD*
Hi folks!
I'm selling this acoustic guitar amplifier - Marshall AS100D. It's the 100W version, not the 50W. It's the 100W version, not the 50W. It comes with:
  • Roqsolid cover
  • Footswitch
  • Manual and original box.
It has a lovely warm sound. Clear too - cuts through even in loud rehearsals. As you'll see in the picture, the handle is missing. I bought a replacement (in picture) but never got round to fixing it. The amp also doesn't have rubber feet, but was never a problem, because I used a stand. Even without a stand, it doesn't wobble.
  • £220 £200. Collection from me in Swindon, Wiltshire, would be great. Or we could meet halfway at a reasonable distance, like Bristol or Reading services. Or I I can deliver it to you at cost. I have the original box with all the protective pieces, so all good there.
  • No trades
  • Bank transfer preferred (I'll provide bank details in private message).
Cheers!
Steve
"The AS100D delivers studio-quality acoustic sound. The AS100D has 2 x 8”, 50W  Celestion speakers with two tweeters providing a high clarity, sonic sound at any frequency. It's perfect for professional players in large venues. Play with any acoustic instrument and duet on stage using just this amp.
  • BE HEARD: With 100 watts of power and two specially designed 8" Celestion speakers, the AS100D has a dynamic range that's perfect for any scenario. You can concentrate on your playing while the amp produces studio-quality sound that's loud enough to fill large venues.
  • MIX IN FX: The AS100D features reverb, chorus, flanger, delay and modulation effects that can be adjusted on either channel. Combine these inbuilt digital FX with your own FX pedals, as well as switching between channels using the included footswitch to create the exact sounds you want.
  • PLAY TOGETHER: The AS100D not only has two channels, but also has separate input features for either a dynamic or compressor microphone, and also an auxillary input for a backing track. This allows you to run both vocals and guitar (or a range of other electric instruments) simultaneously without affecting sound quality.
  • CLEAR YOUR SOUND: Make use of the AS100D's phase switch and frequency adjustable notch filter controls. Allowing you to isolate frequencies causing feedback and eliminate them across all channels."
Steve Tilling - frontman and guitarist for CIRCU5 and EXTC (feat. XTC's Terry Chambers)
  • TheMadMickTheMadMick Frets: 241
    I have the 50 and it's wonderful. Nearly as good as a Trace Elliott.
    GLWTS
  • Circu5Circu5 Frets: 4
    GLWTS
    Thanks Mick! I've never tried a Trace Elliott, but this served me brilliantly. Used it live with TC&I (XTC related band with Colin Moulding/Terry Chambers), and it was great.
    Bump
    Bump
    Price drop - now £200
