Video.
Now, I know this is a guitar forum, so here is the thing, I want to lay down 2 guitar tracks on a looper pedal, but I also want to video it, and I want to cut the video between guitars during the track, how the hell do I sync it all up? Obviously the audio track will be the datum to sync the video to, so, how do I make this happen?
  • octatonicoctatonic Frets: 33725
    Clap at the start, after you start recording and before you start playing.
    You can then line up all the claps.
  • robgilmorobgilmo Frets: 3353
    Thanks buddy, I will give that a try.
  • TTonyTTony Frets: 27343
    And at the end.
    Just in case your audio recording device, and your video recording device, have a slightly different definition of "time".
  • StratavariousStratavarious Frets: 3595
    Do you have two cameras or one?
    you don’t say which editor you are using.
    I have two cameras, but I should only need to use one?
    What I need to do is record an acoustic track, film it, then overdub an electric part, film that, then edit the film to skip in and out of acoustic and electric guitar scenes.
    I have at my disposal, windows movie maker, its Ok, it works.
    I do have DaVinci Resolve but my computer does slow down a bit when I use it.
  • PolarityManPolarityMan Frets: 7273
    having learned the hard way...film at higher than 30fps if you can
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    for sync davinci resolve will use audio to sync multiple clips automatically..its not bad.
    ဈǝᴉʇsɐoʇǝsǝǝɥɔဪቌ
    Cool, I will give it a try, Ive been looking at Sony Vagas Pro, it seems to be the go to for editing? Not sure if my Pc will run it though.
