Just wondering how you guys would hybrid pick this piece by John Hurt ('Shake That Thing')
I'm still getting to grips with hybrid picking, but as you can see I typically assign the plectrum to the 6th and 4th strings in an alternating 'travis' style rhythm, with my pinky (x) assigned to the 1st string, ring (a) to the 2nd string, and middle finger to the 3rd.
When I get to the part circled in red, should i continue with this fingering in order to keep it consistent? I'm just wondering if it's considered bad form to pick the 4th string with the plectrum, and the 1st string with my pinky? I could use my ring finger in its place, but other than interfering with the finger correspondences, it makes the jump down to the adjacent 2nd string more awkward. Another option is to alternate the ring and pinky....
If you’re a hybrid picker, how would you play it?I just want to make sure i'm not spending my time practicing the wrong way!
P = PLECTRUM
m = MIDDLE
a = RING
x = PINKY
https://i.postimg.cc/Y2drStTL/shake-that-thing.jpg
That's more of a classical /Folk thing which is without a plectrum
Shake that Thing is just finger style I think, more folky blues with thumb bassline and finger melody.
I've never managed to train my pinky to very effective so rarely use it
I only dabble in 'pick plus fingers', for what I'd call 'fingerstyle'. For the specific example you've given, it feels more comfortable to just use my middle and ring fingers on the top three strings, with plectrum for the bottom three strings. However, for your example, my strong preference would be to play the piece using thumb, index and middle finger. I pick with the flesh, not nails. Hopefully this isn't all bad advice.
I occasionally pick with my pinky, but that's mainly as a part of grabbing a bunch of notes together or for simple stuff.
As pointed out in posts above, your example is more of a 'fingerstyle' thing to me, but played with pick and fingers.
I'm not sure what the official definitions are. I mainly use 'hybrid picking' between my plectrum and middle finger, in the way Tom Quayle might use it to transition to a higher string during legato, Or to get the Mark Knopfler type 'snap', but using just my pick and middle finger, In those cases the plectrum isn't restricted to the bottom three strings.
