Pa system popping need help
Wrighty22Wrighty22 Frets: 22
Pa system pops like a static pop. Music and vocals come out the pa fine but will randomly pop. The timing between these pops are random. Asking for help. The pa is active and is going through a cloud mixer(zone mixer) using a aux cable. The i pad is located next to mixer. There is also two more speakers upstairs that are connected but not turned on would that cause a issue
Thanks James
  • paulmapp8306paulmapp8306 Frets: 847
    Turn the 2nd pair on and see if the pops are hears there.
    Will narrow  fault to pa, or speakers/cables.    They shouldn't cause the issue though
  • maltingsaudiomaltingsaudio Frets: 3145
    Sounds like it’s a venue PA, so I’m guessing chillers or some such on the circuit
    www.maltingsaudio.co.uk
  • Wrighty22Wrighty22 Frets: 22
    did a bit so when the cloud mixer is plugged in it pops, must be a faulty cloud mixer right
    Could be worth checking, also try plugging the mixer into a different socket
    yeah the cloud mixer is the fault which is annoying
