Mustang bridge onto a Squier Mascis JM
Is it just a case of unscrewing the tuneamatic bridge that's currently there and then dropping in the mustang bridge into the existing bushings or am I missing something?
  • ICBMICBM Frets: 72572
    It's won't rock properly even if the posts go down the inserts. It also may not height-adjust if the inserts don't have closed bottoms because the height screws will push themselves into the wood. You need the correct 'thimbles'.
    I would probably go for a roller bridge which fits tune-o-matic posts if you haven't got the Mustang one already.
  • gusman2xgusman2x Frets: 921
    You'll need to change the thimbles. You can get some from Staytrem, think they're on his ebay shop, and cost about £7.
  • By 'thimbles' you mean the part that's recessed into the guitar into which the ToM posts screw?
    If so, are these difficult to remove?
    I already have the mustang bridge (present from mini gc1).
    @guitarcookie1 Yes, as the little metal cups. The replacement thimbles from staytrem include a screw for removal. You just pop it in the current thimble (after removing the TOM/AOM posts) and turn it with a screwdriver. This lifts the thimbles out. What mustang bridge do you have? Likely you'll have a mis-match of radius. Jmjm is 9.5, and most bridges are 7.25
  • New thimbles received, anyone have any tips for removing the old ToM ones (no removal screw received with the replacement ones)?
    Screw in the post, then use a claw hammer with a piece of soft wood under it to protect the body and *very carefully* lever it out, keeping a good look out for finish lifting.
    Ok, thank you :)
  • impmannimpmann Frets: 12671
    Woah there....
    Unless you bought the correct conversion thimbles from Staytrem they will not just 'fit'. The outside diameter of the T-O-M anchors is bigger than that of the standard Fender thimbles.
    If you buy the conversion thimbles, these include a bolt used to remove the T-O-M anchors (wind the bolt in til it hits the bottom of the hole then crank it some more to lift the anchor out - helps if you warm the anchor with a soldering iron before hand to soften any glue used to retain it.
    The Staytrem conversion thimbles then are a tight fit into the anchor holes.
    I've done this conversion myself in the past (changed it back to a roller bridge - its better with the closer-mounted trem IMHO) so if you get stuck, give me a shout.
  • impmann said:
    Woah there....
    Ok cheers :)
    I bought the correct sized thimbles from Staytrem (12mm) but they did not come with a bolt..
    Contact them - it's probably an omission
    They're not sent as standard anymore due to ham-fisted numpties blaming the bolt for wrecking their guitar's finish...
    They will send you one if you request it separately :)
    Ah! That I can well believe... :-)
    A bit late here but I would recommend the wilkinson roller bridge.
    It an easier/cheaper upgrade and probably the best suited upgrade for a closer trem placement.
    All My CP Jag use the roller bridge. In fact anything with a TOM gets a roller bridge in my house :-)
  • CorvusCorvus Frets: 2935
    Easy & safe way to remove bushings is use a bolt, a washer and a socket from yr toolkit. Or similar random parts from the "might be useful one day" stash -
    http://www.alleykat.co.uk/images/stuff/lp/pulled_bush_2.jpg
    And to insert then, wind in a bolt part-way and tap home with a hammer.
  • GavRichListGavRichList Frets: 7198
    Second this; I have one fitted on my Squier J Mascis, and couple that with shimming the neck and you've got yourself one hell of a good'un. Bright as you like.
  • Mustang bridge all fitted; took about twenty minutes including new strings & setting intonation...
    The guitar sounds "bigger" and tuning stability is much improved. Can't say I really notice the mid-matched radius though.
    I've been thinking about replacing the Gotoh TOM that I put on my JM Jazzmaster with a Wilkinson Roller bridge.
    Sorry if I'm being a bit dim here but I think the posts on the JM are 6mm but the holes on the Wilkinson are 4mm. Did you switch the posts too or am I getting it all wrong?
    Link to my trading feedback
    I used the posts that came with the Wilkinson
    Which Marcus jazzmaster do you have? White or purple?
    Bah feckin tablet. Mascis***
