Body Top | Solid Red Spruce |
Body Back | Solid Mahogany |
Body Sides | Solid Mahogany |
Body Shape | Orchestra |
Bracing | Guild® Scalloped Red Spruce |
Rosette | Black/White Striped |
Finish | Gloss Nitrocellulose Lacquer |
Body Depth Upper Bout | 3.75″ (95 mm) |
Body Depth Lower Bout | 4.25″ (107 mm) |
Body Length | 19.5″ (495 mm) |
Body Width Lower Bout | 15.25″ (387 mm) |
Body Width Upper Bout | 11.75″ (298 mm) |
Overall Guitar Length | 41.5″ (1055 mm) |
Guitar Weight | 4 lbs |
Body Binding | Tortoiseshell |
Purfling | B/W/B |
Neck Material | 3-Piece Mahogany/Walnut/Mahogany |
Neck Shape | “C” Shape |
Neck Finish | Gloss NItrocellulose Lacquer |
Scale Length | 25.5″ (648 mm) |
Nut Width | 1 11/16″ (42.8 mm) |
Nut Material | Bone |
Fingerboard Material | Indian Rosewood |
Fingerboard Radius | 12″ (305 mm) |
Fingerboard Inlays | Mother-of-Pearl Dot |
# of Frets | 20 |
Tuning Machines | Gotoh® SE700-05M Vintage-Style Open-Back |
Hardware Finish/Plating | Nickel-Plated |
Truss Rod | Dual-Action |
Truss Rod Wrench | 4mm Hex Truss Rod Wrench |
Bridge | Indian Rosewood |
Saddle | Bone |
Bridge Pins | Bone |
Strings | Guild® L-350C Standard Tension Coated Phosphor Bronze, (.012-.053 Gauges) |
Case or Gig Bag | TKL Premium Hardshell |
Strap Buttons | End-Pin |
Pickguard | Tortoiseshell |
