Working from a blank allows you to choose your own string spacing and match the fingerboard radius.
https://graphtech.com/pages/tusq-nuts
Closest approximation, 0.5mm off each side shouldnt be the end of the world with your string spacing
Brilliant, thank you for that.
This is the best one, apart from it's about 2mm too wide, otherwise perfect: https://graphtech.com/collections/tusq-nuts-guitar/products/tusq-nut-slotted
I'll just file it down.
Can't believe how much money I've spent doing up this piece of junk guitar. Oh well - it's been fun and I've learnt a hell of a lot.
Once I've got it in working order and played it for a while I'm stripping it all off and going to re-finish the body.
Thanks.
Okay cool - yes will do.
I took a before pic already, and have since changed the hardware and pickguard.
Obviously the pickguard didn't fit so I had to file off quite a lot of it and made a dogs dinner of the part around the neck, so may well buy a new pickguard and re-do it.
