Want a delay/reverb pedal with midi?
rockmonsterrockmonster Frets: 838
edited July 2021 in FX
I do! I would like to replace 2 basic pedals one reverb one delay with one pedal with both and midi. I want to do this so I have more loops I can use on the Gigrig G2. Does such a beast exist? Or is it complete overkill?………..
  • monquixotemonquixote Frets: 17648
    GT-1000 CORE or an HX Stomp.
  • robinbowesrobinbowes Frets: 3048
    Eventide H9.
    R.
  • Source Audio Collider? Everyone seems to love that
  • rockmonsterrockmonster Frets: 838
    edited July 2021
    I’ve heard there’s a latent delay on the switching (irony perhaps!
    I’ve heard there’s a latent delay on the switching (irony perhaps! :)) the
    Worth seeing which firmware version that was with, sometimes these issues get fixed in later versions. Looking at the change log there are some things which they’ve tweaked when switching presets
    Only read about it- no experience of said unit.
  • jacklawteyjacklawtey Frets: 284
    I think the Red Panda Context V2 does both to some degree?
    No midi and no delay?
  • KeyrohKeyroh Frets: 59
    Context v2 has delay as a secondary feature.
    I'd suggest the RV-500. It has robust midi capabilities as well as access to any digital delay on each algorithm plus the space echo. You can set it to run two algorithms at once in series or parallel
  • shaunmshaunm Frets: 1627
    Specular Tempus?
    Still no midi though.
    shaunm said:
    Specular Tempus?
    Midi?
  • AntonHunterAntonHunter Frets: 923
    It has MIDI. Via TRS or USB.
    Ah didn’t spot that!
  • Ventris has the echoverb engine which can do reverb and delay. In fact since it is a dual DSP box, you could run two at once if you wanted!
    Bye!
    It has both of those things.
  • russpmrusspm Frets: 445
    You could always add a Gigrig Loopy 2 to give you more loops on the G2. Separate pedals give you more options.
  • octatonicoctatonic Frets: 33806
    H9 covers a lot of ground.
  • WindmillGuitarsWindmillGuitars Frets: 731
    +1 for GFI Specular Tempus - awesome pedal
    www.windmillguitars.com - Official stockist of Yamaha, Maybach, Fano Guitars, Kithara Guitars, Eastman Guitars, Trent Guitars, Orange Amps, Blackstar Amplification & More! (The artist formerly known as Anchorboy)
    edited July 2021
    You are right but real estate is in short supply unfortunately.
