Eventide Micropitch - where in the chain?
mpcmpc Frets: 0
As per the title,
Where would you recommend putting this pedal in the chain?
  • mal1971mal1971 Frets: 16
    After chorus would be my suggestion. Run your chorus in to it in stereo, detune by -7 on one side and +7 on the other, add some reverb and delay after and you will get close to the la session clean sound.
  • tekbowtekbow Frets: 1699
    Modulation > Delay > Reverb
    For this particular type of modulation, that is. And in post, so FX loop, or with a lineout fed into it.
    This effect/ algorithm is really designed for a WDW setup going into stereo Delay and reverb.
    As soon as it gets summed to mono, you really loose the benefit of it IMO.
