Wall socket
HootsmonHootsmon Frets: 13990
Moved in to a new house………plugged our microwave in a twin wall socket that also served to permanently power the gas cooker/electric oven, both workin,great.
got up this morning and both microwave and cooker are not working into the wall socket but are fine in other sockets………nothing has tripped in the fuse box department
any thoughts…..? I am starving
tae be or not tae be
  • octatonicoctatonic Frets: 30352
    Broken socket.
  • ColsCols Frets: 3735
    Bit odd for a cooker to be powered off a wall socket; normally they have their own circuit due to the high current draw.
    But yes; most obvious reason is the socket has failed.
  • Danny1969Danny1969 Frets: 6871
    You might find there's a proper cooker circuit that's failed and the wall circuit is spurred off that, hence no power
  • ICBMICBM Frets: 56983
    A lot of efficient modern ovens are low enough powered to run from a standard 13A socket - our is, which surprised me at first but it came with a moulded plug on it!
    But if none of the trips have tripped, I think it must be a faulty socket. Most likely one of the terminals not screwed down tightly onto the wires. This is quite common - and a fire risk since a bad electrical connection can generate serious heat if it's making partial contact.
  • HottubesHottubes Frets: 292
    edited July 20
    The switches on the sockets themselves may have gone bad. Do you mean a cooker switch, with a built in socket ?
    The cooker should be on its own 6mm radial cct, sometimes they have a built in socket and sometimes they're just a switch to turn the cooker on and off. The cooker switch usually just feeds the cooker connection unit, that powers your oven.
  • StratavariousStratavarious Frets: 1427
    New house as in new build?
  • WazmeisterWazmeister Frets: 7144
    Check the RCA and see if the switch has dropped; the kitchen circuit is sometimes separate.
  • vizviz Frets: 8003
    Some trip switches don’t look like they’ve tripped, there 75% still in the up position. But they’re loose to the touch. if you push it all the way back up again you may find it was off.
    Anything that isn’t pentatonic is pretentious wank -  LastMantra
    more on the strength of my ability to own a PA than to play a guitar” - ICBM
  • HootsmonHootsmon Frets: 13990
    Huh…….what’s that and is it beside the cooker.?
    RCD
  • DominicDominic Frets: 9509
    It's a great big switch on your consumer unit that protects circuits .........usually at one end or in the very centre.
    Kitchen should always be it's own separate ring
    is it a socket or an isolator (fused spur)
    Even if it's low consumption an oven should be switch fused
  • boogiemanboogieman Frets: 8625
    Probably just a loose wire in the back of the socket if it was working ok yesterday. Are you confident with looking at electric stuff Hoots? Turn off all the breakers or the main switch at the fuse box before you do anything else, only then unscrew the socket and have a look. If you’re not sure though, get an electrician in.
  • SnagsSnags Frets: 3056
    edited July 20
    @boogieman Given Hoots other comments on the thread, if he's not just having a giggle he might be better off to get a knowledgeable mate or a sparks in ... Wouldn't want him to enact Sporky's quote that gets used as a sig.
  • spark240spark240 Frets: 1735
    Post a pic of the fuse board…
    Mac Mini i7, 2.3Ghz.
    Opened up the wall socket........it's a twin socket and the cooker has been plugged into the right hand side and working for ages i expect.....fed with 3 wires and they are sound.......the socket only went tits up when i plugged a microwave into the left hand side (it was working OK) and left microwave in situ over night.........next day, no lights on the xmas tree ma
    What now? Cooker and MV are working OK in to alternative sockets
    I wanna impress Hooters and fix it
  • ZenOvertoneZenOvertone Frets: 173
    New board time - no RCD's and looks like plastic casing :-)
