I found a Samsung Syncmaster 151s monitor on the street missing its power cable/supply.
Hopefully it’s just what I need to see the internal settings on my Hamichord (Hammond B3 clone) via a vga cable, allowing me to select from a host of B3 models (see, it is a music query and not simply tech).
From photos it looks like all I need to run it is a simple power cord without any power brick. Its specs are below. Am I right?
POWER DEVICE
Type
power supply
Nominal Voltage
AC 120/230 V
Frequency Required
50/60 Hz
- Power Consumption Operational
The manual doesn’t indicate a power brick but I could be wrong.
also I’ve had a lot of luck in the past contacting the manufacturer directly
If I remember correctly, the software has a single menu page with drop down choices. As simple as it is fantastic a clone. Now all I have to do is keep my eye open for an old usb mouse and I’m all set.
https://imgur.com/gallery/MIO6Rnu
C5 it is!
