1964 Fender Bandmaster & mod reverb with bag
brooombrooom Frets: 1175
edited November 2021 in Amps £
1964 Fender Bandmaster - £900 (available in London, but can be shipped)
blackface head from the Fender electric (pre-cbs) period. It has new power rail electrolytic capacitors, new 470ohm screen resistors, but everything and a replaced output transformer (same spec).
Everything else is pretty much original.
Photos: https://flic.kr/s/aHsmWQqUH6
Mod reverb pan with two external bags. - £50
1967 Fender Vibrolux Reverb - £3200 (available in London, but can be shipped) - REMOVED
Basically original with new filter caps and some plate resistors changed (pretty much basic maintenance)
Comes with two eminence/alessandro ga10-sc64 speakers.
I'm currently wiring the power supply correctly (previous owner was using diode for rectifiers) and to remove the polarity cap and wire the fuse in the right place (previous owner hadn't changed it), also will be adding new F&T filter caps (with the right values) and new sprague electrolytic caps for the cathodes.
Photos: https://flic.kr/s/aHsmWQNDYM
