FS: Yamaha MS400 active PA speakers - Pair £225?
4114Effects4114Effects Frets: 3131
edited October 2021 in Misc £ tFB Trader
Yamaha MS400 Active PA peakers 15" 400watts Pair. Great solid pair of PA speakers, built to last.
300w to the LF, 100w to the 2inch compression driver. Decent SPL and efficient amp means they fill a room no problem.
I've owned these for years and found them great. Downsizing now as all I generally do is acoustic or venues with in-house PA.
Fully working and sounding great Few scuffs and scrapes consummate with age, built to last though so will be good for many years to come. Would suit a gigging band or DJ.
Good solid sound, great drivers in these. Proper transformer supply, no modern switched mode class D, so the watts listed are what you get. Fully functional, slight scratch noise from turning pots but when set no problem.
One speaker has just had the HF diaphragm replaced. I used a genuine Eminence replacement rather than 3rd party rubbish.
Offers around £225 for the pair, trades always possible
I also have a Soundcraft 16 channel mixer I could throw in as a possible deal - so you're ready to go.
Any questions please ask.
Specs below:
Type: Amplified 2way bass reflex powered speaker (Bi-amplified electronic cross over network)
Components LF: 15 in. cone HF: 2 in. VC, Titanium diaphragm compression driver
Frequency Response: 50Hz ~ 16kHz (-10dB)
Maximum SPL: 124.5dB (1m)
Dispersion: 90 degrees (H) / 40 degrees (V)
Dimensions (W x H X D): 449 x 683 x 379 mm (17-11/16 x 26-7/8 x 14-15/16 in.) Weight: 24.2kg (53.4 lbs)
Maximum Output Power: LF: 300W at 500HZ.
THD=1%, RL=4, HF: 100W at 5kHz. THD=1%, RL=16
Crossover Frequency: 1.6kHz (30dB/oct)
Input Sensitivity: LINE: +4dB* MIC: -50dB*
Input Impedance: LINE: -30 ohms MIC: 5 ohms LINE Input/Output: XLR-3-31, XLR-3-32, Phone (balanced, parallel) MIC Input: XLR-3-31 (balanced)
Power Requirement: AC120V 60 Hz Power Consumption: 120W * 0dB=0.775V
  • 4114Effects4114Effects Frets: 3131
    Bump. I'll take offers on these. Just taking up space ...
  • roundthebendroundthebend Frets: 1137
    necro bump....are these sold?
