NDLD
New Dummy Load Day
A mahoosive 150W resistor screwed to a heatsink recycled from a dead 70s transistor amp, with thermal paste in between. I know, ideally the fins should be vertical, but the resistor on its own is rated at 45W with no heatsink, so this will do for my purposes. The second jack socket allows me to connect a DI box and IR loader if needed. The exposed copper wire between the sockets allows for easy connection of oscilloscope probes.
