I’ve just bought an FMT Tele (the Korean 2 Humbucker fixed neck one) to take over main duties in the pub rock (dad rock?) band/s that I do and occasionally use as backup.
I’ve used it for one gig so far and it seems great.... but!!!...
Ideally I had the idea of getting a Trem put in it.... and I notice the body depth is pretty shallow. Anyone out there already tried it with this model? Any ideas? Modifications? Mill the Trem block down and redrill the holes? Build up the back of the guitar with a laminate?? How easy or difficult??
Regards
I think the Master Vee Telecaster Trem and the Trem King all interfere with the body and the Tele Stets bar doesn't
Kahler. Very easy install with a top rout only, completely covers the footprint of the old bridge, and you don’t need to fit the locking nut if you don’t want to - with a straight string pull like a Tele, locking tuners are nearly as good.
Fitting a through-body trem is an enormous job to get right. I wouldn’t even consider it. Better to get a different guitar with one if you want that.
Or just buy a Whammy pedal…
I don’t mind bigsbys on some guitars but I really don’t see this guitar that way. I’d really like to be able to get my inner Jeff Beck/Alan Murphy on with it. That ain’t gonna happen with a Bigsby me thinks.
There is also the Washburn Wonderbar/Shift 2001 too - less invasive to fit than the Kahler, but still needs two screw holes outside the footprint of the old bridge. Obviously that only matters if you want to take it off again! But it's also a massive faff to set up, ungainly and extremely ugly, so you probably will...
I agree that this guitar wouldn't suit a Bigsby, even though they're fine on traditional Teles.
https://floydrose.com/products/frtx
