ALL SOLD: 1 BIG guitar case & 2 cheap spider and diago pedal boards
TeyeplayerTeyeplayer Frets: 3226
edited December 2021 in Parts £
Happy to post any of the following, priced for collection from Kettering, Northamptonshire. Postage will be whatever it costs for an item of the weight and dimension and hopefully I can find a box big enough!
Thomann ‘Xtreme’ oversize case -SOLD
Intended for all those pointy metal sorts  or generally larger guitars like firebirds, Vs, Explorers, BC Riches, Rhandy Rhoades (etc) and of course basses.
Just to make life a little easier here are the full details on the Thomann website:
https://www.thomann.de/gb/166446_gitarrenkoffer.htm?glp=1&gclid=EAIaIQobChMIvfiW7_Pj8wIVQrDtCh3eSwHKEAQYAiABEgJeZvD_BwE
This is brand new without the tags or box. Photos taken with measurements to help clarify space, although rough internal measurements are: 115 x 41,5 x 9 cm
Includes moveable pad to support guitars of varying size.
Save yourself the cost of £83 (including postage) of getting this from Thomann and pick this up for a bargain price. £50 collected from Kettering, Northamptonshire, just off the a14.
https://www.flickr.com/gp/157224850@N02/6Qnt9q
2 pedal boards, £20 each collected.
Diago showman pedal board - SOLD
This is clearly used, but will go on for many years yet. Great size if you have a ‘few’ pedals. Only thing of note is the bottom material has come loose. I’ve restuck it as a temporary fix with carpet tape but would benefit from some heavy duty glue -this is obviously a common issue as I’ve seen a few of these where the material has been removed and pedal tape put down in its place.
72cm x 34cm
https://www.flickr.com/gp/157224850@N02/8T7613
£20 collected.
Spider pedal board - SOLD
Flight cased pedal board that can either be removed for gigs or remain in the base of the flight case. Sturdy, solid and already has some pedal tape on the base.
50cm x 30cm
https://www.flickr.com/gp/157224850@N02/Yji31S
£20 collected.
