anyone made a pup testing guitar?
I'm sure there was a thread once where someone showed a pic of a pup testing guitar? Did I imagine it?  it had big cutouts down the body so that you could slide pickups under the strings.
I quite fancy the idea of knocking one up from spares. I have a naff body that I was going to bin as it was weird scale length, but it would probably be ideal for a bodge type pup tester as I wouldn't feel guilty about killer routs.
  • Danny1969Danny1969 Frets: 10455
    I though about it but though cutting a hole all the way through and loading the pickups from the back would be the easiest way
  • martmart Frets: 5205
    axisus said:
    I'm sure there was a thread once where someone showed a pic of a pup testing guitar? Did I imagine it?  ...
    No, you didn't:
    Actually, that wasn't the photo I was looking for. I remember reading somewhere that when Fender developed the Dave Gilmour Strat they had a pickup-testing Strat, designed so the whole pick guard assembly slid out. I know I saw a photo, but couldn't find it from a quick scan on the net. It's probably in a book somewhere (most likely the Black Strat book, I guess).
  • citizen68citizen68 Frets: 172
    Declan at Deacci Pickups (formerly RD Pickups) concocted a clever way of swapping humbuckers quickly in / out of a donor Ibanez hard tail guitar.
    It involved a few large routs as mentioned above and the pickups were suspended in two rotating corks at each leg - think the corks were mounted on springs to help with height adjustment.
    I'll try & get a few pics
    Seemed like a good idea.....
  • WezVWezV Frets: 16787
    There has been a few.   IIRC @GSPBasses has done a strat one that slides out from the treble side, its one of the few pickup testing guitars that doesn't sacrifice all aesthetics
  • GSPBASSESGSPBASSES Frets: 2351
    edited August 2014 tFB Trader
    Yes I made a quick change system for Feline Guitars.
    The how and why link.
    Hi @WezV you beat me to the reply.
  • OilCityPickupsOilCityPickups Frets: 10684
    I use a swimming pool routed Strat ... but that is a much better solution!
  • ecc83ecc83 Frets: 1639
    "anyone made a pup testing guitar?"
    No, but I did make an "amp testing pup"! I had a gash Di Mazio single coil laying about and put it in a die cast box together with a 470k volume and tone pot and .047 (IIRC) cap.
    This was done to get noise figures for amplifiers with a real world input termination and was handy for listening for problems without a guitar connected which would just feedback. YES! even with the strings damped!
    In fact even the pup in the tin would feedback and I had to cast the whole thing in tallow to  use the high gains I wanted. It also needed to be a looong way from any mains traffs!
    Dave.
  • axisusaxisus Frets: 28341
    @gspbasses that is a very elegant solution!
  • JayGeeJayGee Frets: 1267
  • RoxRox Frets: 2147
    What about a guitar testing pup?
    But seriously folks... I did wonder a year or two ago whether there was a way to slot humbuckers in from the back of the guitar - then a backplate with wood inserts - so you just screw the plate off, unclip the 'buckers, and hey presto.
  • EvilmagsEvilmags Frets: 5158
    Look at the Fishman Fluance Web page. One in there
    Another front loader system was that used by Dan Armstrong in the Plexiglass guitars, with interchangeable pickups.  I used to play these, great guitars, really cool looking, weigh as much as a neutron star, but I didn't really rate the pickups that much.
    Here is a modern Ampeg AMG100 wooden guitar built with the same system, demoed by everyones favourite, PGS Andy.
    Take a look, and you'll get the idea.
    Duration 3:27
