A bass player friend and I have been working a recording project using Logic Pro X on my Mac. We have a track that's a bit Freddie King-ish that we're both liking - except that the bass player is not all that happy with his bass sound on it. He DI'd his track using a bass that has a natural sound that's close to a Fender Jazz (it's actually a Danelectro). And he wants it to sound on the recording more like a Precision or even a Gibson EB0 - more dull thuddy and muddy and "old" and with less clarity.
I've tried a few obvious things from the standard Logic feature set including the "60's bass amp" preset, a bit of boost or distortion or fuzz (e.g. a RAT), and of course EQ, but I haven't yet been able to make it sound like he wants - that clarity keeps on coming through. Anyone got any thoughts or suggestions? (It's not worth buying anything specially, so it would have to be something that comes with Logic...).
Thanks for any inspiration...
Literally any foam or sponge material you have lying around could work (as long as it isn’t rough). I used a piece of foam from an old flight case.
Neck pickup only
Fingerstyle rather than plectrum or fingernails
DAW Channel EQ (as distinct from amp model TMB controls)
Apple Logic Pro X Sub Bass plug-in
Airwindows Tape plug-in (simulates various unpleasant artefacts of analogue tape that just happen to make drums and bass sound huge).
You might want to consider the use of compression on the upper, attack frequencies. Also, loosen the neck bolts a little, not enough to let the neck shift, but enough to decouple it acoustically from the body for more rubbery midrange. You also have the option of slipping a little kitchen towel or kleenex in there if you are prepared to detach the neck completely. (Added bonus: If the paper towel doesn't work you won't need to take the neck off to remove it.)
Failing all that, you might be better off borrowing a cheap p bass from somewhere and then following all of the advice above.
Now...having said all that, this guy seems to be getting pretty close to a vintage vibe on a 59 bass in the first few minutes. However even he comments on how bright the bass is later on.
https://www.youtube.com/watch?v=drlqqCwzrpc
[This space for rent]
Dunno.
This Discussion needs more Freddie...( the bassist on this I think is from the show's own backing band)
And knock the tone control down by at least half.
I don't think this was the first recording of an electric bass despite what the title says but it is Monk and it was an early Precision, flatwounds, thumb near the neck and the kind of thud that could have graced a Freddie King recording.
What he said. I like that sound and, although a very occasional bass player, it blends in nicely with the others I play with.
Been watching Hitchhikers on Britbox!
