Two pickup bass. Therefore, master volume (no centre detent), pickup balance, 2-band EQ.
EDIT: Chances are that the pickups are passive and only the EQ controls are truly active.
The other one at the front goes from Fat/Punchy to Clear/Humming, by the look of it - set to taste, or to Fat/Punchy if hum is a problem. (It might not be, some of the narrow hummy pickups are actually also hum cancelling.)
One of the other two goes from Thin to Full-Sounding. Set to Full.
The last one goes from Dull to Hiss, with a useful detent in the middle so you don't accidentally turn it up beyond halfway.
Most bass players don't feel the need to touch them again after that.
Does that help?
