Has anyone tried one of these in a 68C princeton?
PA Hire and Event Management
They don't seem too bad, even though it's a pretty small box for a 12". The limited edition one that came with a Celestion Blue sounded fine, and it did with a Jensen Tornado too.
Probably a bit too stiff and dark for a Princeton, but again I haven't tried it.
Looking to put something better in a 68 vibrolux, currently swapped in some ragin cajuns (which sound great) but they are HEAVY compared to the cheapo stock ten30s.
Is this the price that needs to be paid for tone? Or is there a happy comprise?
Or how about the Eminence 1028k? 1.3kg apparently. Full disclosure: I haven't tried this speaker. However I always come across people recommending it for fender amps and it's one I really want to try.
Ideally i'd get a 12 that weighs the same or maybe even less, hence the thought of the creamback neo but the WGS stuff looks great a reasonably priced which is a surprise
I found similar speakers with large magnet like the Weber 10f150t were much louder but increased low mids more than I liked. If you're after punchy that might be what you're after.
British style speakers like the Celestion gold 10 or Emi Ramrod changed the flavour too much for me too.
Emi 1028 is great but from memory more scooped and perhaps not quite as efficient as the GA10. Still good but I thought it would be better in a tweed style amp or in amps with multiple speakers.
Someone was selling a 1058 in the classified section recently. I haven't tried one but might be worth investigating.
I now have the tasty combo of ramrod + ragin Cajun in my vibrolux and it sounds massive! Weighs a tonne but I'll just have to deal with it, sounds scary close to an old super reverb I played through at a gig a while ago from memory.
Now I need to find the perfect speaker for my Princeton...
Currently got a neo creamback in there and it's great but I wish it was a tiny bit brighter, as some of you know these 68 reissues don't really need any help in terms of bass and are quite full in the mids so I'm not sure if the creamback is the best fit as it's accentuating low, low mids and mid mids - any recommendations on pretty efficient 12" speakers that are:
A ) a suitable wattage for a Princeton
B ) reasonably bright sounding but also tight in the low end
I'm thinking something alnico? But not really sure...
One of the Jensen Tornados would also be good - probably the 80W one, or maybe the new 'Vintage' one which Fender use in the Tonemasters.
Only thing that put me off is the Jensen neo I have is the 100w...
As long as the rating is higher than the maximum output of the amp it's fine.
Otherwise, definitely the Eminence GA SC-64.
