Greetings Folks,
Ive had this kit for a while, and as I tend to do its taken a while to move beyond the initial new-toy stage to actual construction. This is a recreation of the mofified JCM800 used on Appetite for Destruction and is my 2nd kit from
@Modulus_Amps , the first being a JTM Black Flag (glorious clean and overdriven and a royal pain to tame volume despite the added MV).
I am not planning on any modifications this time, as the amp already has a MV and the circuit seems a little more complex to start with. Instead, im going to try and concentrate on improving neatness of wiring.
So, the turret board is being populated. Wire links went first, followed by a left-->right approach for the remaining components. I would have liked to keep the component leads a little straighter, and neater when bent to accomodate space issues. But didnt want to overdo it and risk breaking leads.
The photo's should be self-explanatory, and though some of the solder joints look a little bare, there is plenty of solder that has flown down the turrets. It seems to be a very 'fluid'solder that im using.
I'll get the board finished today (component wise) and make a start on the chassis later.
As always, comments and critique is welcome. And a very positive shout out to Michael at Modulus for sterling advice, patience and product!
The mostly bare turret board
https://i.imgur.com/luA0oLk.jpeg
Close up of diode array
https://i.imgur.com/uBtB4UJ.jpeg
Further close up of 'interesting' component lead bends.
https://i.imgur.com/Xgra3kP.jpeg
The board as it stands
https://i.imgur.com/VPlXIDe.jpeg
Cheers for looking
Anyway, looks an interesting project! I'll be back to see how it goes. All that wiring looks a tad daunting, although I guess the instructions are clear.
I'm off to check out the company ...
Should be a very good amp!
Good luck with the build - you can't beat a great PTP valve amp.
When you get there I can help you try out different things to get the best from the amp though.
I'll get some of the chassis wired up today, but im off next week, partly Covid+ve enforced, so hopefully get it mostly finished by next weekend.
Thanks again,
Adam
https://i.imgur.com/BMZWo7h.jpeg
https://i.imgur.com/Uvzfw8N.jpeg
https://i.imgur.com/CcQRDNV.jpeg
Adam
Anyway, here are some photos.
First chassis soldering - the AC socket. Heatshrink is much easier with a small hotair gun.
https://i.imgur.com/IIgD9Jg.jpeg
And the start of the heater twisting
https://i.imgur.com/fo0rZI9.jpeg
Input jacks and some of the control pots. Relatively thin gauge shielded wire a little more awkward than the 22AWG used elsewhere. There may be a better way to attach the parallel cap/resistor.
https://i.imgur.com/ejFjlA2.jpeg
Hooking the offboard wiring around the turrets via threading the wire through the board. Again, trying to keep things neat.
https://i.imgur.com/tq7iHse.jpeg
Offboard wiring attached. A million spiders legs.
https://i.imgur.com/fQxELct.jpeg
Now the real fun begins. Transformers attached and cables through.
https://i.imgur.com/hK81QzA.jpeg
The caps-of-doom. Another 5-6 wires to attach. Note the other wires providing easy access for the soldering iron tip....
https://i.imgur.com/B5tSUMe.jpeg
Close up of on/off switches
https://i.imgur.com/KgHXMlQ.jpeg
Pre-amp bases. Not too bad.
https://i.imgur.com/a2H9D6w.jpeg
Power bases. Getting worse.
https://i.imgur.com/l3lSQ5N.jpeg
Caps-of-doom. Spaghetti vomit
https://i.imgur.com/EUwldus.jpeg
As it now stands. I need to replace a resistor after trimmimg the wrong side of the solder join. And i cracked a fuse holder that also needs replacing.
https://i.imgur.com/o01gytp.jpeg
As always, comments welcome and criticism accepted as advice
Cheers,
Adam
Basically these are my 2 favourite amp designs, and I'd love to build one, but you know, electricity and all that.
I have to run my 50 watt JCM900 through a powerbrake, which is obviously strangling it, but by god, the tone of it is glorious, can only imagine how nice yours must sound, fingers crossed the new one works first time.
Devotion/perserverance/madness - its hard to tell which! Ive been running the Black Flag through a hotplate, but Im not convinced Im getting the best out of it. It truly does sound glorious at volume though Whereabouts are you? You're very welcome to try it out.
I thought Id already posted up the Black Flag, but I cant seem to find the thread. Let me sort out some pix and maybe an open A soundbite.
Cheers,
Adam
P.S My little boy, Isaac, and I have also finished the turret board on a Tweedle Dee kit, also from Modulus. I'll put up a separate thread for our joint build
I think the solder joints are all good - even if they look a little 'empty' on some of the turrets. I was finding that the solder was flowing in a more 'liquid' fashion than Im used to (Michael had donated some fancy lead-free solder to trial), and that it tracked right down into the turret holes. The only real worry I have, solder-joint wise, is on the big caps (the 3-terminal blue beasties), and fitting all the connections to a small tab. Plus the ground connection on said caps is awfully close to the chassis itself. I'll be taking the amp up to Michael @Modulus for a check-over before I power it up anyway.
Cheers,
Adam
So. Other than that, what amp *should* I try and recreate next?
Adam
