I decided to turn my Marshall JVM 215C Combo into a head because I want the flexibility of using different cabs depending on the size of gig, playing at home etc.
Why not just buy the head version you ask? The head is standard size - massive - so doesn't sit on a 1x12 or vertical 2x12. Also, I love the plexi look so wanted it to match my Studio Vintage.
...and I like a project!
It's made of laminated 9mm and 6mm MDF to make 15mm thickness. It's MDF because birch ply is hard to get in 15mm and I can't see the sound properties mattering for a head. Front and back are 12mm. I ended up having to buy a new 1/2" router so I could use the 3/4" roundover bit. I plan to build a 2061cx sized cab next, so it will get used again.
I just need to get a new gold Marshall logo to finish it off and I'm looking at getting a new faceplate made up by Modulus.
Very neat, it would have looked ok if you had done it the other way up, but it's worth going the extra mile with the new face plate.
They're a bit thicker than the original, though, so you need to allow for that.
Looks great!
Can't wait to get this fitted, it looks amazing! Fingers crossed my measurements were accurate enough!
Bandcamp
Bandcamp
