So, we use an X-Air and I have the FOH balance pretty much right but some of the channel faders are almost maxed out. I don't have the ability to rig it all up before our next gig so have - hopefully - a simple question: If I go into the snapshot, I want to reduce everyone's fader by (audibly) the same amount so that the FOH mix sounds the same - and I just turn up the master. I'm fine with input gains etc. but what scale do I use to bring everything down? Is it XdB or a linear amount on each slider (say, on an arbitrary scale of 1-10, drop them all by 20%)? I'm assuming the former but wanted to ask people who know before I mess it up.
TIA
Dick
If I was in your position, I would make the changes and save the settings as a new session, reduce all channels by, say -6db, and push master up by same amount. To be clear, make a copy of original session before making changes, make changes on new copy.
It would be doing no harm to your original session, and if the results were not as expected, the NEW version could be modified - while still having original as ultimate backup.
