I've got an Epiphone Explorer bass with the barrel type saddles on the bridge.
I want to get the action a bit lower as it is a tad high, but the barrels are right down on the deck already. Neck relief is fine, no big upward bowing of the neck, it's not far off straight.
So, rather than trying to find a bridge that will let me get the string below about 12mm off body, I thought I would just take a millimetre or so off the bottom of the saddles. I can then wind them down a bit further.
Anyone done this? It seems it ought to work..... If it doesn't, I can still just set them back up at the height they were. They'll just have a small gap under them.
might be the answer!
The Explorer body is a slab with no forearm contouring. It ought to be in the interests of playing comfort for the strings not to be ultra close to the flat top of the body.
My nearest uncontoured slab equivalent is an ol' RIC 4001. Edge of bridge pickup metal surround to bottom edge of low E string, 12mm.
It might be wiser to change to a new bridge with slimmer saddles and overall height profile. e.g. Schaller 3D-4G.
