https://www.thomann.de/gb/mackie_dl_1608_power_supply.htm
Other than that ..... Although it uses a locking barrel connector other than that it's just a standard 12V 4 amp I think .... I'm using on on Wednesday so can check polarity for you then if needed but assume it's centre positive so quite common
If you want a locking barrel connector, they range from ~ £3 - £16.
Eqd Speaker Cranker clone
Ross
Thanks Robin, I'll have a look on this page, I have very limited knowledge on power and am unsure if standard ones without the locking barrel will work. I'm assuming they will? Appreciate your help.
Ross
Power is just power, after all. As long as the voltage is correct, the current capability is at least the required capacity, and the connector is physically the right size (and polarity) it will work.
R.
