LOL 0
Wow! 0
Given this has multiple modes and is relatively inexpensive it seems like a great choice.
The footswitch is the one thing about it which has a bit of a budget feel, possibly because I’m used to switches with a definite solid click, and this sits on a spring above a push-button on the circuit board. I imagine it’ll be fine for my purposes - if I have any issues in warranty I’ll post an update.
https://i.imgur.com/JiaZ3BK.jpg
http://www.thefretboard.co.uk/discussion/57632/
All TC-designed pedals do work as you'd expect and engage effect on press, not release - although I seem to remember that wasn't the case with a TC Nova that I used to own, but that was some time ago now.
"Proper" TC pedals engage on press and many of the TonePrint-enabled ones have TCs "Mash" feature, as well, which allows you to use the pressure of your foot on the pedal switch to act as a form of expression control. For example, to control tremelo speed between the upper/lower limits you defined in your Toneprint - rather useful.
I don't mind the switch too much, the soft action is a lot better than some pedals where the switch is really stiff. But, yes it does activate as you lift off. Interestingly I have the new TC Stereo Chorus Flanger and the switch activates the same way.
I'll admit I don't love it that way, but as long as you don't leave you foot hanging around on the switch it's fine.
Edit: I have had another pedal in the past where it activated as you lifted off the switch, but I can't remember what it was - possibly an EHX one.
