I want to start with a few setup tweaks to my guitars - theres a few with the odd high fret that needs attention. Im pretty skilled at metal work so am happy to start fret work tweaks.
I discussed with the Crimson guitars team at the Guitar Show and saw their tools (listed below). They seem good quality and I believe in buying good stuff, but are there any cheaper solutions to any of these at similar quality?
Crowning File £20
Levelling beam - 16" £33
Notched Straight Edge £40
Fret End Beveling File £40
Fret Levelling File £36
Adhesive backed sandpaper 180 / 220/ 320 / 400 £8.50 each 25mm x 5m
Karma......
Ebay mark7777_1
Ive seen notched strait edges self made from a metal rule
Fwiw, a triangle file with edges ground off is not really a crowning file. Yes, It can be used to crown the frets, but there are specific crowning files that do that task better.
Great for dressing the ends though
Instagram
Instagram
1. Fret rocker. Mine is an impulse purchase from Ben on the Crimson stand at the Guitar Show a couple of years ago.
2. Levelling beam. You can make your own with a section of extruded aluminium, double sided tape, and good quality abrasive paper.
3. A crowning file. Mine is from Chris Alsop. With it came a fretboard protector and fine grade abrasives for polishing. https://www.chrisalsopguitar.co.uk/shop/guitar-tools
Regarding fret levelling beams, somebody post here recently about Metals4U.co.uk who can cut aluminium box section to custom length for a really good price.
off eBay:
cheap fret rocker,
cheap fret crowner,
some of those (excellent) flexible sanding squares
I stick sanding paper to spirit level for leveller.
Made my own notched bar to check neck is straight.
I'm not knocking people spending a lot on super tools, I would love them all but my life is on a budget. Everything has worked fine, made 6 instruments so far.
https://theartoflutherie.com/fret-crowning-files/
Instagram
Ian
Going to see if a mate can level the bottom of an old metal spirit level to do the levelling beam.
I have a 24” straight metal ruler so will use that to check neck is straight.
I see there are hollow radiused diamond crowning files available - are they easier to use than a triangle type?
Ebay mark7777_1
I settled on the offset handle diamond file, same as the link I posted above. I actually also use it to dress the ends
The one crimson sell as a crowning file is arguably better for learning how to crown, but not best for speed and repeatability
I also had a normal hollow crowning file , gurian file set and half round file, and didn't like any of them. Just got chatter
More recently I had a cheap diamond file from China which had no shape to the hollow curve at all
Instagram
A fret-rocker is a must
Files are a personal thing, I have the cranked-neck 3-in-one file with a blobby handle and a straight one for crowning, and a ground-edge triangular file for the rounding the fret ends (admittedly from Stewmac, but back when the exchange was good!)
I dont use a notched edge, and whilst handy I have a niggling suspicion they are a solution looking for a problem,
Fret rubbers/micromesh for polishing afterwards (Dremel polishing mop and Autosol is fantastic if you have one)
Thats it really.
Have given a guitar with a few cowboy chord divots a light skimming to get methodology sorted, and now in the middle of one that needed a good level (two high frets) in middle of fretboard.
Made a make shift levelling gauge with three guitar ballends (spaces ruler 3mm off fretboard) and a straight metal ruler - works ok!
So thank for all the advice - Im happy with what Ive got just need to source a quality set of emery papers (600 - 1000 grit).
What brands/suppliers are good for wet and dry papers?
Ebay mark7777_1
Fandeli, 36002, 120 to 2500... https://www.amazon.co.uk/dp/B08F8HKJK1?ref=ppx_pop_mob_ap_share
