And so it finally begins....
I'm butchering Graham's work here. Plan is to install a Staytrem bridge, AvRI Jag/Jazz Vibrato and a couple of Mojo Wide Range Jazzmaster pickups - all of which have been ordered and some of which have arrived.
Got a bit of routing to do once all the hardware lands, in the meantime I'm starting to look at the neck finish so I can decide what to do with the body.
The wood is London Plane which I've never worked with before. I have it a light coat of yellow stain to see how the grain reacts. Actually, it hasn't really popped, but that's ok because it's so prominent maybe it need to be slightly subdued anyway.
Have rubbed it back after stain (which it needed anyway) but left ala lot of the stain on the marked frets. Still thinking about this, but tempted to stain the rest of the frets red and rub back a bit. I'm thinking about a Fireglo type finish to the body...
I'm pretty sure I'm going to finish this with Nitro over the top of any stain I apply. I think the body will just be nitro finished, although I might stain the back, which is Ash, first then rub back.
I've got some metal pickup surrounds being made which will cover the existing routing. Might get a scratch plate made, might not.
Feedback
I can tone it down with sanding, staining and tinting nitro over to suit so will be fun to play around with it.
The grain of the Ash on the back is fabulous. Put some yellow stain on it to bring the grain through which has taken nicely. Will rub that back and see how it looks / feels before deciding how to proceed.
Mine is insanely loud unplugged and has a very nice semi acoustic vibe, rather than a thinline vibe - bags of volume and really fun to play.
Rubbing back the stain and exposing the grain, then oiling it gives it an almost pearloid effect.
Looks great, and the red and yellow grains are exposed in different light, not together.
I'm thinking to hit it with some vintage tint nitro when it's dry to reduce the contrast. I'll also use clear brown on the back and just let the overspray take the edges of the neck and hopefully cloud the fret edges slightly.
The Swamp Ash grain has lots of lovely reds and brows in it which the stain and oil has emphasised. Probably use a clear yellow nitro over the top of this.
Need to file the edges and de-burr but they should come up nicely.
A bit of oil next.
Nearly there now. I need to work out the wiring and string it up.
Thanks chaps, it is a nice looking thing. The pickups are a bit of an oddity, never fitted JM's before but they seem to need some foam below them to push the pickups up into the covers. Also a spring on each of the four screws means it's a fiddle-ass job fitting them. All part of the fun I suppose!
