Using an EV PXM12MP.
At home/studio I use studio monitors.
Because you have to take the modeller plus a power amp plus a cabinet.
Given modellers have excellent cab emulations now it is just easier to go to FOH and use either in ears or a stage monitor.
I still have a Matrix power amp that I previously used with a traditional cab- I haven't used it in about 2 years.
I had a matrix power amp before, it was ace.
Ebay mark7777_1
would really like to try the orange pedal baby and a valve power amp like the fryette power station or KSR PA 50. I have read a lot of people also like plugging into the FX return of a bluguitar amp1
I started with an old Carlsbro 100W SS amp and fed my HX Stomp into the FX return. Being extremely happy with the results (or easily pleased?) I looked to replace the Carlsbro with something a little more modern. I then purchased a Marshall MG50GFX and the results were better still. But because I wanted to slimline my digital rig I sent the Marshall back, and after further research based around my available budget I purchased:
A TC BAM200, and a Harley Benton GPA-100 (as a back up).
Both are fed into a 1x12 cab with a 4ohm Celestion Hot 100 (transplanted from the Carlsbro amp).
There are probably better options out there at the upper end of the market, but I don't hear any reason to get anymore spendy. YMMV.IMHO.MTC. etc..
I'll be honest, I've never had such a no-compromises rig. I know that sounds weird to say, but not being forced to compromise my lead tone for my rhythm tone (as I used to when using valve amps with shared EQ) is bloody marvellous, and I've had numerous guitarists from other bands ask me where I've hidden my amp given how good it sounds.
Nowadays, you can get the SD170 for about £200 second hand, which is about as bargainous as it gets, and there's easily enough headroom even into 8 ohms - through my 2x12", I can drown out an enthusiastic drummer before the amp runs out of steam.
It's tiny and fits into my Helix backpack pocket and is absolutely plenty loud enough to keep up in a full band scenario. I tried using both pre-amp and full amp blocks on the Helix, and decided that full amp blocks just sounded better, fuller and more articulate.
I have an IR of my cab in the Helix too, so for live use I run one output without the IR into the Gnome and cab for on-stage noise and monitoring, and then the IR loaded output goes via XLR to the PA.
Wis' awarded for this great idea.
I'm curious as to what you didn't like about the SD? For my money, it's absolutely perfect - and the active EQ is astonishingly powerful (eg turning the bass control up gives you "more bass" rather than "more sludge").
As with all the A-list modellers, though, it's not necessarily about the gear but rather the patch. There's no way, for example, that a patch that sounds perfect at home through monitors is going to sound as good at band volume. I usually maintain two sets of presets - one for home, and one for playing live.
