However, if you're building a proper early JTM (mk1 with 5881s) then you need a 6k6 pri-Z such as this - https://www.tube-town.net/ttstore/tube-town-outputtransformer-dual-primary-for-marshall-jtm45.html
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
https://modulusamplification.com/JTM45-Output-Transformer-Based-on-RS-Deluxe-P5295837.aspx
Don't run EL34's with a proper RS clone, the primary winding wire is thin compared to the 50w units that came later and would likely fail with constant overloading
The TAD 50w OT is not a great substitute for someone looking for an RS clone, wrong Prim Impedance, std grade laminations rather than m6, wrong winding pattern , different frequency response etc They do sound different.
I don't know if it is from this thread or not but we will be winding a 6.6k RS style OT this week for a customer.
I saw that shootout and preferred your offerings. I want to build a tweedle see soon and will be grabbing one of your OTs. Probably the smaller vintage spec one
https://www.inmadout.com/
Very highly thought of in the Dumble building market and will do custom specs
Ironically it’s what made the JTM45 quite different-sounding from the Bassman - as well as the closed 4x12” Celestion cab vs the open 4x10” Jensen - because they didn’t compensate for the very different output impedance and reduce the negative feedback ratio, with the result that the JTM has almost three times the NFB of the Bassman.
These are the TXs sold by Tube-Town in DE, they're very, very good
Rift Amplification
www.riftamps.co.uk
