I'd use a wire brush wheel and take it all off. Then a buff with a polishing wheel. You might not have access to those though.
Take them off first!
It will make a surprisingly big difference to take them off and clean the *tolex* though - the dirt around them makes them look a lot more unsightly than they actually are.
Interestingly, my Googling suggests the chassis straps are chrome plated, but the corners are nickel plated. @ICBM ?
I'd guess the straps and the handle ends are chrome, but the corners look nickel and the rust is less flaky. I'm not sure whether this is an indication.
Ironically, I've owned four Super Champs... and I can't remember!
The amp had cleaned up really nicely, so I may just buy new hardware. I don't think it'll look that bad with new stuff now it's tidy.
I don't suppose you've got any 6C10s kicking around?
Replace the 6C10 with a 12AX7 - the socket will mount across the hole, with a small gap around the edges - and use the two gain stages for the mixer gain stage and the phase inverter. Then separate the two halves of the 12AT7 reverb driver (which is just paralleled) and use the second half for the reverb recovery instead of the missing stage of the 6C10. You need to rebias the driver (1K5 resistor from memory) but other than that it’s just a case of moving the wiring.
It would have been better like that in the first place - designing an amp around such an unusual valve was a bad idea, and there’s actually no need to parallel the reverb driver, there’s still plenty even with only one half.
Thanks John, I'd seen a previous post.of.yours with this mod. I'm also pondering making a compactron plug (impossible to find) out of a compactron socket (easy to find) with some soldered in pins, then building some sort of adapter box with 2 x 12AX7s.
EDIT - but having now, just seen the pic - I think new ones are in order
I got given an abrasive sponge pad that cuts a bit better but stuff can still be brought back to a shine with 0000 and one of those fret polishing micro abrading jobs. Bit less effort overall…
