If it's used the previous owner may have fitted a different speaker then put the old speaker back before selling it but used
longer screws ! You could remove a screw and if it's too long buy replacements or contact Orange and give them your amp
details and they should be able to sell you the right sized screws. First check the speaker is the right one as speaker chassis
can be different and this might account for the screw coming out beyond the front of the baffle board. Hope this helps.
speaker and see if it's fallen down behind the speaker grill cloth. If you find it you can relocate it. It can be fiddly but it can be
done. Just relocate the little flanges and press them back into position then place the speaker back in position and gently
locate the screw thread. I'm guessing the screws are not the originals so you need to check out what length you need. Hope this helps.
on second thoughts forget the threaded inserts
thread or gently take one of the speaker screws will screw into any thread that may be there.
If there is thread in each of the hole then it's just a case of using shorter screws so you could get replacements or cut the
exiting ones. If none of this works the it might be best to remove the baffle board then the speaker cloth and do the job
I have a Fender Princeton and change the speaker and one of the T Nuts came out and like you say it was tight but I got a
magnet and managed to get it back to the speaker hole then you should be able to guide it into the hole that was drilled for it.
The other thing you can do because the screws are too long is to use some washers to stop the screws pocking through the
speaker cloth. Hope this helps.
Very glad you got it sorted
