Finding a "quasi-dominant" in different modes
TanninTannin Frets: 5519
edited July 2022 in Theory
In a practical sense I daresay I can work this out for myself, but I'd like to know what the "proper" way of doing this is.
Suppose I'm playing in a particular mode. My example is E phrygian. I want a chord that is going to bring me back to the tonic. In E major, the strongest pull is from the dominant, the V chord,  B7 > E. In E minor, the usual thing seems to be to "cheat" a bit and play a B7 anyway, even though, strictly speaking, the v chord is minor and B7 is out of key.
In E phyrgian, the diatonic V chord is B half-diminished, which has a very strong pull sure enough, but it pulls us to C, not really back to the tonic  Em.
Should I play a B7 anyway? Or do some other thing? (Meaning "should" in the sense of "what is the most traditional?")
To my ear, the obvious chord in E phrygian that really, really wants to come back to the tonic is the II chord, F. But what does the theory say?
More broadly, and without asking for an epic-length essay  of an answer (well OK, maybe I am) how about the other common modes?
  • stratman3142stratman3142 Frets: 2201
    edited July 2022
    Tannin said:
    ...In E minor, the usual thing seems to be to "cheat" a bit and play a B7 anyway, even though, strictly speaking, the v chord is minor and B7 is out of key.
    In that context I think of the B7 as being part of the E harmonic minor scale.
    It's not a competition.
  • KeefyKeefy Frets: 2293
    F7 - think of it as the b5 substitution for B7.
  • vizviz Frets: 10713
    edited July 2022
    Yeah, you can always do a “perfect cadence”, i.e. going up a perfect 4th from the dominant position (or “5 chord”) to the tonic (or “1 chord”)
    You can do it in Ionian and Lydian (the only two scales that have a major 5 chord (a “V”) in their diatonic scales)
    You can also “cheat” as you put it, and deploy a V or a V7 in any other scale - minor, dorian, phrygian, mixolydian, as well as any other non-diatonic scale you fancy playing in, like Hungarian major for example, in fact, whatever scale you like. Even though all those scales strictly speaking call for a minor 3rd on the dominant. Basically whenever you want to return to the tonic chord, you can come off a V7 if you fancy. That’s just making music. There is NO RULE that states you have to, or even you should, stay within the diatonic notes. In fact I can’t think of a single classical piece that does!
    And of course you can also deploy a dominant chord any time you want a perfect cadence, even if you’re not returning to the 1 chord. For example in major, you can do III7 - vi. You don’t have to do iii - vi. That’s called inserting a “secondary dominant”. It’s a way of creating a strong resolution to the 6 chord. Instead of just going from the 1 to the 6, you can go via the 3, and majorize it, thus making the resolution to the stronger, or more “perfect”. In other words, making a “perfect cadence”. Like in the first verse of That’s Life.  The III7-vi basically behaves like a V7-i.
  • CrankyCranky Frets: 2630
    edited August 2022
    I like the way it sounds running a G/Bdim arpeggio
    up to a high F then fall back into an Em for the finish.
    Also, Em and Cmaj7 are basically the same chord.  As is the Bdim and G7.
  • KittyfriskKittyfrisk Frets: 18913
    Sounds like you might need to try B/D/S Minor.
    Less dominance....
