Pedaltrain Info and Dual Lock
BeexterBeexter Frets: 617
edited September 2014 in FX
After years of getting by with homemade plywood pedalboards, I've finally bitten the bullet and ordered a Pedaltrain Jr. Despite me carefully wiring up my own boards with custom length George L's and screwing pedals down with bike links, I've come to the conclusion that it is a royal PITA to swap stuff out. I drill holes big enough to fit the cables through, but not the jacks. Looks neat as you like but changing pedals around is not a 5 min job. Hence the incoming Pedaltrain..
However, I'm thinking of going with 3m Dual Lock from the outset for attaching pedals to the board but cannot for the life of me find any suppliers of the 50mm/ 2' wide Dual Lock in the UK - anyone have any ideas? For those of you using Dual Lock, which type are you using and do you just lay two strips of the 25mm next to each other along the bars on the Pedaltrain?
