Any Other Fixes of This Tuning Peg Problem
BellycasterBellycaster Frets: 5866
edited December 2022 in Bass
As per the Title. Preferably cheap and without replacing the entire mechanism.
My G Tuner peg head is slightly loose.
I don't have these adhesives.
My current solution is an elastic band stretched tight from D to G string which is stopping the rattle, but I'd like something a bit permanent.
Thanks.
Only a Fool Would Say That.
  • Paul_CPaul_C Frets: 7842
    A little bit of superglue will do it, in my experience.
    Almost anything thin enough to run into the gap and dry should probably do.
  • ICBMICBM Frets: 72611
    Clear nail varnish, heated wax, or jam a bit of paper in there if you can get it in (try Rizla).
  • Cheers. I wasn't sure on the Superglue as I didn't know if it would be too brittle. I might try a bit of Tin Foil for colour match @ICBM ; :)
  • FunkfingersFunkfingers Frets: 14572
    Fussy basket that I am, I would remove the offending machine head and bushing completely before introducing adhesive or heated wax.
    Break the task into stages.
    Build up thickness, then, press in the bushing - ideally with the proper tool.
    The Rizla paper or PTFE tape has the advantages of being non-destructive and entirely reversible.
    For the superglue method, I would still remove most of the machinehead. Press the bushing fully down. Apply touches of adhesive around the rim of the bushing from the rear of the headstock. Protect the finish.
  • I had this problem on my Squier P. A blob of blu-tack sorted it out, never bothered to mount a more permanent fix
  • Dave_McDave_Mc Frets: 2365
    I read that quickly and thought you were suggesting "jam" for a minute!  =)
    Might work... it's sticky.
    May attract wasps in summer though.
    You'd need to watch you don't end up with a buzzy tone
    (sorry  =) )
  • RockerRocker Frets: 4993
    You are in danger of getting a swarm of suggestions now....
    Nil Satis Nisi Optimum
  • SporkySporky Frets: 28670
    Jam is the correct answer to more questions than most people suspect.
    That was a lot better than my awful attempt at a joke!  =)
  • Is the Metal Malleable enough to squeeze together with pliers to "Nip" the Clover Peg?  :)
    No - it won't grip tight enough unless you can take it well past the elastic limit.
    Have you got a small-diameter punch? You can try tightening the rivet pin.
    Not sure, I'll have a look or see if I can scrounge round at Work. The rubber band is working wonders and isn't that noticeable, but I won't want to settle for that permanently.
    Alternatively, I can nab some glue from work and see to it when I've got a bit of time.
  • Not sure I can actually identify the Rivet Pin @ICBM ;
  • BillDLBillDL Frets: 7386
    I could be wrong, but I think this is the rivet pin @ICBM was referring to:
    Not all clover button bass tuners use a pin fasten the flat button to the worm shaft though.
    Tuner.jpg 83.3K
  • Thanks, will check again @BillDL ;
    Yes, although often they're smaller, nearly flush with the surface and more difficult to see.
  • Sadly there is not one on my Pegs @ICBM and @BillDL ;
  • No biggie, I'll sort some glue out over the Holidays.
