So I have been going down the fuzz rabbit hole and looking to order an Analogman Sun Face pedal.
There are quite a few options to choose from, although I understand the NKT275’s from years ago are the most desirable but no longer available to buy new and selling for a considerable mark-up.
After watching countless YouTube videos, I think I am choosing between two of the germanium transistors - either the standard 2SB171 or BART but I am open to considering any of the others offered.
This will be used for a Strat and Les Paul into a Princeton Reverb.
Does anyone have any views on these specifics transistors and any other options to add in to the order?
I mainly use mine with the 1974x amp, which is Marshall named but a bit black sheep of that family. My point anyway is not Princeton. It sounds best with my Tele but I have used it with a Les Paul running into lower input of the brighter channel and using a Beano Boost to get a different sound since it didn't feel like there was the range to play that single coils have.
If you're not sure what you want it's probably worth just asking Mike at analogman, he's pretty good on recommending
I’m tempted to order one just with the sundial, side jacks and fuzz pot on/off options.
I have pedal board power but understand from research that the best sound seems to come from a battery and therefore no led also seems like the best bet to avoid battery drainage…
Strangely, I don’t miss the on/off. I have an on off on my beano boost but still opt to leave the pot where it is and just unplug the input jack. Probably because I’m bending down anyway to do that to the sun face. I’d have it if I was speccing one but wouldn’t pass up on a well priced second hand for not having.
Cheers.
Always a bit difficult to talk about amplification & a 'Marshall voice' without discussing originality & derivation
https://edmorgan.info
