FS: Rode, NT1 mic & AI-1 interface kit with popshield (demo inside)
danishbacondanishbacon Frets: 2702
edited February 2023 in Studio & Rec £
Selling this on behalf of a friend. It has the nicer square popshield and rycote style SMR shockmount. Will take photos of the actual kit tomorrow. The mic lead has been misplaced. He's looking for £250 posted for it.
It was used to record the following track (vocals and guitar):
https://www.facebook.com/BillySharpMusic/videos/1213546362515988/
or if you don't have facebook: https://www.youtube.com/watch?v=O46_3HypXQ4
Full specs here: https://www.pinknoise-systems.co.uk/rode-ai-1-kit-usb-interface-nt1-microphone-w-shockmount-pop-shield-bundle.html
Rode AI-1 Kit - USB Interface, NT1 Microphone W/ Shockmount & Pop-Shield Bundle
This Rode Bundle Includes:
  • AI-1 Single-Channel USB Audio Interface
  • NT1 Large Diaphragm Condenser Microphone
  • Shock Mount
  • Pop-Shield
  • XLR Cable
  • USB-C/A Cable
  • Ableton Live 10 Lite
The perfect first step into home recording
RØDE’s AI-1 Audio Interface is stacked with incredible technology to ensure recording on your computer is easy, versatile and sounds superb. The Complete Studio Kit comes with the AI-1, RØDE’s peerless NT1 large diaphragm condenser microphone, a shock mount and all cables. Let’s get started.
As for inputs: the AI-1’s got both kinds…
The AI-1’s single input is a NeutrikTM Combo Jack, which takes both a 3-pole XLR (common to most microphones) and a quarter-inch jack common to most electric instruments like guitar, bass et al. Layering tracks is as easy as plug in, set level and go.
No cords barred (and other puns)
The Complete Studio Kit comes with the RØDE NT1 studio condenser microphone, a shock mount, pop-shield, RØDE XLR cable and USB-C/A cables to transfer data from your AI-1 to your computer, and power – including 48V phantom power to your AI-1.
Superior Headphone Amplifier onboard
Not only does the AI-1 deliver crystal clear audio to your computer software, but headphones have never sounded sweeter thanks to the discrete studio-quality headphone output and level control.
Rode NT1 Cardioid Condenser Microphone
Features
  • Large 1" condenser capsule with gold-plated membrane
  • Cardioid polar pattern
  • Internal Rycote® Lyre® based capsule shock mounting system
  • Ultra-low noise, self noise of only 4.5dB (A)
  • State-of-the-art surface mount electronics
  • Available with included RM2 mount (NT1-SINGLE) or with SMR shock mount (NT1-KIT)
  • 10 year extended warranty when you register your microphone
The NT1 is a revolutionary new 1" diaphragm condenser microphone from RØDE.
Although the body of the new NT1 closely resembles the NT1-A, the microphone has been completely redesigned from the ground up, with the only shared component being the mesh grille.
RØDE’s design engineers approached the NT1 as a marriage of innovation and tradition, starting with the capsule which is a completely new design. Codenamed the HF6, it is the perfect example of RØDE’s fusion of artistic design approaches and cutting-edge manufacturing techniques, and features a sound signature reminiscent of the famous microphones of old while at the same time exhibiting extremely low noise.
It has been developed with a focus on detailed midrange response, coupled with silky smooth high frequencies, and warm, round, bass reproduction to make the NT1 an absolute standout in its class.
In another world-first for RØDE, the transducer itself is suspended inside the microphone using Rycote’s industry-leading Lyre system, minimizing external vibrations at the capsule level. The capsule is then married to high-grade electronics that have been designed to provide the lowest noise level of any studio microphone available. The NT1 is an incredibly quiet microphone, measuring only 4.5dBA of self-noise.
Its body is machined from 6061 aluminium and then nickel plated for resistance against corrosion. Finally it is coated in a durable, military-grade ceramic layer, using advanced electrostatic application techniques developed by RØDE to ensure an extremely hard wearing finish that is resistant to scratches or marks.
The NT1 is supplied with the revolutionary new RØDE SMR shock mount. Featuring a unique double-Lyre suspension system, the SMR enhances the existing superior vibration cancellation of Rycote’s Lyre system by using a smaller inner Lyre to act as a tensioning element. This maintains each Lyre in the neutral position where it is most efficient at cancelling vibration. The SMR’s removable all-metal pop filter is as effective as it is visually striking, providing an integrated solution for plosive protection that is easily washable and designed to last as long as the shock mount and microphone.
The NT1 is designed and made in Australia, and is covered by RØDE's industry-leading 10 year warranty.
