final countdown help
i have been learning  Europe  final countdown solo  the part with the fast  arpeggios i think is alternate picking, but i am not sure if its all alternated picked for every note?
the way i am playing for the fast arpeggios  is  notes   B up,  D down,   hammer on F#  pull off D .   and on , is this right or should i be alternate picking all the notes in the arpeggios .
  • vizviz Frets: 11649
    I just pick the first note in each group.
  • I think it's displaced groups of four with a single pull-off...
    But I can't decide how I prefer to pick it:
    • strict alternate - D U D (pull-off), U D U (pull-off), etc. bit odd due to the start of each group switching between D and U
    • downwards economy - D D U (pull-off), D D U (pull-off), etc. feels like you need to slide with the position shifts
    • upwards economy - U D U (pull-off), U D U (pull-off), etc.
  • dazzer22dazzer22 Frets: 44
    I have better results using upwards economy  , Tried alternate picking all the notes but can't get the speed ,
    I'm inclined to agree (no pun intended)...weird as 'downwards economy' doesn't require any string escaping.
    They all make good exercises though ;)
    Next up: YJM's 'Rising Force' solo?
  • Danny1969Danny1969 Frets: 12606
    The first 2 notes are down for me. The picks going in that direction so it just falls onto the next note. It sounds double tracked on the record to me.
    Hybrid picking in a half Knopfler  / half pick works quite well .. in face I can hybrid pick it faster than I can using the pick alone.
    It's good fun whichever way you do it.
  • From the man himself, it appears to be alternate picking:
    Danny1969 said:
    ...It sounds double tracked on the record to me...
    Listening to the isolated track it's actually harmonised!
    First time I've listened to it that closely ;)
  • If anyone is interested, I just knocked up a full transcription (link is in my sig).
  • DrCorneliusDrCornelius Frets: 8669
    Nice ! Look forward to learning that - I love that solo but it’s not anything I’m ever going to play in the wild so I haven’t ever thought about learning it until now
  • RolandRoland Frets: 10171
    digitalkettle said: I can't decide how I prefer to pick it
    Whatever feels and sounds right to you. My first priority would be “what does my version of the song need?”. If you really can’t decide then the second would be “is this an opportunity to learn a different way of playing these hammers and pull-offs?”
  • When you break it down, it's basically 5 repetitions into 4 beats of the bar...   but never when I do it.. I find it tricky to avoid playing 4 into 4..  it's still flashy and Joe Public couldn't care less...
    Poly-rhythms are my Kryptonite I reckon
    My trading feedback
    i think its more of a speed issue 16th notes with 5 notes being played in 4 beats bar , i can just about do it but its still very hard and has to be timed spot on if playing alone to the backing track,  I don't think i could ever alternate pick each string at that speed so its about finding what works .
  • CaseOfAceCaseOfAce Frets: 1906
    edited March 2023
    For a start the Norum vid above is in Eb tuning...
    To play it at that speed down pick the first B string note, then up stroke the high e (second) note and immediately hammer on and rapidly pull off the 3rd higher note - and then it's just a case of repeating the arpeggios in that fashion.
    If you try and play that 3rd note in each arpeggio with a downstroke and then pull off.. you won't get the same speed / feel.
    Damn .. I can't believe I've finally got this down.! ;-)
    Like a lot of guitar stuff - once you've figured out the party trick it becomes a lot lot easier...
  • stufisherstufisher Frets: 1213
    Once I've got beyond the obvious 'sticking points' with the Beat it solo I might have a go at Final Countdown.
    As always, my starting point will be Carl Brown so perhaps @dazzer22 you might find this useful:
    Oh I could hear the harmony but if you listen carefully it sounds like 2 guitars play one part in unison and then 2 guitars play the harmony part in unison. It's a thicker sound than the more traditional simple Thin Lizzy / Iron Maiden approach.
    What the part actually is ... in essence,  is a rocked up version of the outro solo from Sultans of Swing but moving the triad shape rather than modifying the inversion like Knopfler does.
    In essence, yes, but Sultan's arpeggio patterns repeats on the beat, Final Countdown does not, which add the complexity.
    When I play it, it always feels like a race to fit the 5 repeats in..  almost ignoring the 4/4 time. Kryptonite!!
    It was the same with a Gary Moore lick in "Walking by myself"
    My trading feedback
    Recorded it for a laugh...ended up going with alternate picking for the arps:
