Switch help please
RkphilpotRkphilpot Frets: 173
edited July 2023 in Making & Modding
Hi all, electrical help please?!
The coil tap switch on my strat has perished. I need to replace it.
It's the Japanese green one in the pics below.
It says on it
3A 125VAC
1A 250VAC
All the replacements I can find say
3A 250VAC
5A 125VAC
What does this mean? Will it make a difference?
https://www.flickr.com/gp/198435672@N03/dBv3748dvA
  • SporkySporky Frets: 28636
    edited July 2023
    The VAC is the maximum voltage they can handle.
    Guitar pickups typically put out about 1VAC tops (with apologies for such a generalisation) so you'll have plenty of headroom.
  • RkphilpotRkphilpot Frets: 173
    Thank you
  • FunkfingersFunkfingers Frets: 14553
    One word of caution. Some MIJ DP3T switches have their inner contacts operating the opposite way around to US/UK C&K versions.
    This can mess up the middle position of an on/on/on switch selecting stud/series/screw. (Lace Dually pickups are sometimes wired this way.)
    Reviving this thread to ask the knowledgeable folk.
    Can I swap the stomp switch on my pedal build for the latching switch pictured?
    https://flic.kr/s/aHBqjBaWUD
  • ICBMICBM Frets: 72539
    No - it's only a SPST switch, which is nowhere near enough - you need a 3PDT like the footswitch. (You may be able to get away with a DPDT if you don't mind losing true bypass or the LED switching.)
    Unfortunately, finding a 3PDT toggle with a 1/2" bushing so it fits the hole in the casing is difficult and going to be expensive - but if you don't mind fitting a couple of washers to make the hole smaller, mini-toggle 3PDTs are common.
    Ok, thank you I figured it wouldn't be simple. Really appreciate your help, thank you @ICBM ;
    Dimarzios do the EP1111, which is 4PDT (but on/on/on) and 15/32" so might be fairly easy to fit - I've used rubber grommets to seat them neatly in a 1/2" hole.
    They have a particular switching pattern though, so you'll need to draw up the wiring you check it'll work. The middle position will be odd.
    Couple more questions added to this thread if you'd be so kind.
    I bought a mono 'switched' jack socket but I don't need it be switched. If I plus a TS cable in it will the switch part matter? Or will I need to put a jumper from the hot terminal to the switch terminal?
    Also with the switch how do I tell which are ground terminals? It's going to be for a killswitch so I just want to send signal to ground.
    Pics here;
    Thank you
    https://www.flickr.com/gp/198435672@N03/422Rs79j5m
    edited April 5
    You can ignore the switched connections on the jack.
    Multimeter to tell how the switch operates, unless it has NC and NO on the terminals (normally closed and normally open respectively).
    Legend, thank you @Sporky ;
