Hi
anyone have any experience using Wealden or Whiteside 2”(50mm) spiral trimmer cutters?
Ive been using a wealden 2” bit to do most of my body and neck template routing but keep getting some tearout on end grain even when Ive sanded very close to the template before routing. The Wealden bit i am using at the moment has straight cutters and i wondered if its worth investing in a spiral upcut or downcut bit for my router table. I’m using a heavy Trend T11 in the table - so its not the router causing wobble etc.
any thoughts much appreciated
pete
Tearout might be going the wrong way vs the grain. Or cutters that aren't sharp enoughyou might also be able to use guide bushes to limit the cut on the first pass or two?
Spiral bits are ace, but as you say they're spendy.
I once didn't check a tool path properly and had the CNC machine plunge an £80 spiral straight into the machine bed. No-one was happy about that - fortunately as usual I had the emergency stop in my hand.
My builder pal uses a similar one from Radian which he likes a lot.
I also use a 12.7mm triple helix downcut cutter on my pin router, the first cut is done with a 14mm pin, then the final cut with a 12.7mm pin. This gives a super smooth finish, but these cutters or exceedingly expensive. However, this is offset by the time they save on any sanding you do after the router cut. It's also worth pointing out that spiral cutters last considerably longer than normal straight cutter.
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
ps - any good tips on keeping bits sharp or re sharpening? . I think my 2” Wealden but might be going a bit blunt now.
guessing slower for the larger bit ? I am using a beefy Trend TK11 tablemounted router which has 8-20k rpm
premium bonds came good with just enough of a win today so
ive ordered the whiteside spiral cutter !
