2 interfaces into reaper
Quick question, I've got a OBNE Beam splitter with 3 outputs, my AXE I/O One has (obvs) 1 input, i've also got a Behringer UMC-22 (2 inputs). Does Reaper allow both device to be used so I can use the three outputs (1 per channel)? GarageBand won't sadly so so its either find a budget interface with 3 (or more) or find a work around.
ta for indulging me (once again)
  • Are you on a Mac? Try setting up something called an "aggregate device" in, I think, Audio Midi Settings, then Reaper might let you select that as an interface. I think. It's been a while and I'm away from my laptop, but I think that's what I did.
    You might run into difficulties with things being in sync with each other mind.
  • spev11spev11 Frets: 364
    Yeah on a Mac, i'll download the reaper trial and give it a try , otherwise I'll have to look for a used 4 in interface
  • I’ve a used Audient Id44 in the classifieds of that’s where you end up.
