Expression pedal for Kemper.
jimkehoejimkehoe Frets: 208
I know the Mission EP-KP1 is the go to pedal for Kemper but are there any others that work well?
TIA.
  • susbemolsusbemol Frets: 411
    Pretty much any expression pedal works well with the Kemper. What might work best for you depends on how you would like to use it (ie volume/gain only, morphing effects settings, wah, etc).
    I would concentrate on the overall size, travel range and whether or not you would like a toe switch (to switch between volume/wah, for example).
  • jimkehoejimkehoe Frets: 208
    Thanks. Generally purely as a volume pedal.
  • MusicwolfMusicwolf Frets: 3670
    I use a Boss FV-500H with mine.  Works fine.
    Excellent/ Thanks for that.
