Air fryer plastic/chemical smell ?
Emp_FabEmp_Fab Frets: 24557
I've been using my air fryer for about 18 months and it's still giving off a rather unpleasant chemical/plastic smell.  I can't say if it's affecting the food taste - I haven't noticed, but it's not inspiring confidence that we're not eating contaminated food.
Does yours smell and have you found a solution?
Offset "(Emp) - a little heavy on the hyperbole."
  • darthed1981darthed1981 Frets: 12149
    Nope ours doesn't smell.
    Which make or model? You checked for recalls just in case?
  • EricTheWearyEricTheWeary Frets: 16303
    Not that I've ever noticed. The only problem we sometimes have is if the fan drives something up that hits the element. So cooking, err, very light food (making tortilla chips out of unwanted tortillas for example). It smells then.
  • RaymondLinRaymondLin Frets: 11998
    I have the Ninja and no smell.
  • RiftAmpsRiftAmps Frets: 3189
    My Ninja stinks if I have it too close to the wall and the exhaust ports heat up the tiles
    Rift Amplification
    Handwired Guitar Amplifiers
    Brackley, Northamptonshire
    www.riftamps.co.uk
    You checked for Xwings targeting your exhaust port with proton torpedoes?
  • SporkySporky Frets: 28918
    Aren't they like kettles, in that before you use them properly you're meant to wee in them, and run that through?
  • swillerswiller Frets: 1355
    give it a wash. after 18 months its probably due one.
    Dont worry, be silly.
    Well it's best to wee in everything just to be sure.
    Gets a reaction from guests when you tell them as well.
    edited March 15
    That should be carved in stone over the entrance to every public building.
  • Emp_FabEmp_Fab Frets: 24557
    I wash it after each use.  Unless you're suggesting I dismantle it to clean the internals!  It's an Asda jobbie - Scoville.  The smell appears to be coming from the non-stick coating on the basket and the tray.
  • ToneControlToneControl Frets: 12034
    have you tried unwrapping the food before cooking?
  • boogiemanboogieman Frets: 12462
    Ours doesn’t smell, another Ninja.
  • mo6020mo6020 Frets: 396
    Our Ninja always stinks of plastic..
    "Filthy appalachian goblin."
    https://edmorgan.info
  • thumpingrugthumpingrug Frets: 2944
    Only has this on first use with ours.  You sure its the tray and not the wiring burning away.
    actually the most likely reason is that you didn't remove all the packaging when it was new - there was all sorts of bits of sticky tape and stuff when I unwrapped ours.
    Manual for my one says:
    BEFORE FIRST USE
    1. Remove all packaging stickers and labels from the air fryer, including the
    tape securing the basket to the unit.
    2. To pull out the basket for cleaning, remove the tape securing it into
    place. Secure the unit with one hand and pull the handle straight back
    with the other hand.
    3. Thoroughly clean the basket and crisper tray with hot water,
    dishwashing liquid, and a non-abrasive sponge.
    4. Wipe the inside chamber and outside of the air fryer with a moist cloth.
    NOTE: During the first few uses, there might be a “hot plastic” smell. This is
    perfectly normal in new air fryers as the material is heated for
    the first time. It will go away after the first few uses.
  • spark240spark240 Frets: 2097
    We have the Ninja thingy....I said from day one it had a strange odour...but the chef dismissed it ...I can still smell it though.
    Mac Mini M1
    Presonus Studio One V5
     https://twitter.com/spark240
    Reddit r/newmusicreview
  • ESBlondeESBlonde Frets: 3596
    edited March 17
    We bought a cheapie a few months back to see what all the fuss was about. It has been used dozens of times and still gives off that plastic smell that concerns me. Herself doesn’t smell it,
    youngest son was a chef and had a non branded unit which got upgraded when gifted a Ninja, he said the old one always smelled but the ninja doesn’t.
    Now we’ve decided there are some benefits I see an upgrade in our future.
  • BillDLBillDL Frets: 7529
    air-fryer.jpg 163.9K
