SOLD Duesenberg 52 Senior in Piano Black, an all round stunner Now £1080
pruddprudd Frets: 670
edited May 15 in Guitars £
SOLD
 a rather lovely Duesenberg 52 Senior. The usual top build quality and design from Duesenberg, playability is awesome as are the tones from the single pick up, it really does have 3 useable positions. It is in stunning condition, home use only and pampered at that. The case is also pretty cool and it comes with all the bits and bobs.
Three stock images:
https://i.imgur.com/UfpLQAU.jpg
https://i.imgur.com/jRkuugJ.jpg
https://i.imgur.com/oPeR9hW.jpg
Actual guitar:
https://i.imgur.com/cUPRGdx.jpg
https://i.imgur.com/kxcVur3.jpg
https://i.imgur.com/tpnIsy5.jpg
https://i.imgur.com/MEWPqhF.jpg
https://i.imgur.com/gluST8p.jpg
Blurb:
CHAMBERED BODY
Large sound chambers deliver a lighter and more resonant guitar compared to a regular solidbody construction.
SPLIT/KING PICKUP
The single Split/King pickup at the bridge offers three sound options: true Singlecoil, true Humbucker and a combination of both.
The newly developed Duesenberg designed Split/King pickup can switch between real humbucker and real singlecoil mode. But it is not the splittable humbucker you might expect.
It actually houses a real singlecoil which can be extended to a full humbucker with a second, specially designed coil to actually deliver the best of both worlds.
As a third option, the pickup can be set into an in between mode where both coils are mixed in a special way to give you even more flexibilty.
The mode can be selected with the 3-position rotary pickup switch at the cutaway while the elegant "Phonico" pickup cover continues our vision of truly independent hardware design.
PLEK PROCESSED
The specially designed Duesenberg Plek process guarantees a perfectly playable instrument in all situations. Every single Duesenberg instrument is expertly pleked for buzz-free playability all throughout the fretboard. It is then carefully finished by hand and precisely set up by a Duesenberg professional luthier. The luthier responsible also leaves his or her signature inside the instrument.
NECK
Type: Set Neck, 1-piece Mahogany
Width: 42,5 mm / 1.67" (nut), 52 mm / 2.05" (12th fret)
Thickness: 21 mm / 0.8" (1st fret), 24 mm / 0.95" (12th fret)
Shape: Medium D
Fingerboard: Indian Rosewood, radius 305 mm / 12"
Inlays: Cream Dots
Frets: 22 Jumbo 2.8 x 1.0 mm
Scale length: 648 mm / 25.5"
Trussrod: Steel dual-action
Headstock: Rosewood
BODY
Type: Solid Mahogany with sound chambers
Top: Carved solid Maple
Dimensions: 44 x 32,5 cm / 17.32" x 12.6"
Height (sides): 4.5 cm / 1.8"
Binding: Cream
Finish: PUR lacquer
HARDWARE
Tuners: Duesenberg Z-Tuners
Bridge: Duesenberg Wraparound Bridge
Strap pins: Duesenberg Standard (Straplock compatible)
Hardware color: Nickel
Strings: Duesenberg Custom 10/50 (010-013-017-028-042-050)
ELECTRICS
Pickup (neck): -
Pickup (bridge): Duesenberg SplitKing Humbucker (Phonico)
Wiring: 1 Volume, 3-Way Rotary Switch
ACCESSORIES
Case: Premium Line Case
NOW DOWN TO £1080 delivered in the UK, I doubt you will find one cheaper
  • dazzajldazzajl Frets: 5874
    Really want! Can’t have!!
    *pouts*
  • pruddprudd Frets: 670
    *pouts*
    "Can have, must have"  is my Mantra =)
    prudd said:
    *pouts*
    Well if you’ll accept a chicken, a guinea pig and my eternal gratitude in lieu of actual cash…….. ;)
  • DrCorneliusDrCornelius Frets: 7307
    *pouts*
    Tbf that is very you ! (the guitar that is, not the pouting)
    *pouts*
    We both know I’m the very pouty one.  :3
    dazzajl said:
    prudd said:
    *pouts*
    Is the chicken a good layer?
    Selling eggs from your driveway is a big thing here in West Wales. I've worked out that if it laid 12 eggs a week I could get my money back in around 9 years based on full egg laying production and at £2.50 a dozen.
    Cant see that I'd have much use for the Guinea pig though B)
  • TheMarlinTheMarlin Frets: 8078
    prudd said:
    dazzajl said:
    prudd said:
    *pouts*
    If it’s any help, it’s alleged that they’re quite delicious!
    It’s just one egg a day per chicken but I can up  my offer to a pair? ;)
    Now open to offers, decided against the chicken and Guinea pig offer =)
    bump
    Bump and price drop to £1080
    bump
    A windy wet bump from the seaside
  • RkphilpotRkphilpot Frets: 180
    Ah this is awesome, I love the look of this
  • equalsqlequalsql Frets: 6225
    Like damn! That's one of the most beautiful looking guitars I've ever seen.
