SOLD!! 2no 5 hole Tele pickguards | 4 ply brown tortoiseshell | 3 ply mint green | £20 posted
dcgdcg Frets: 275
edited May 16 in Parts £
https://i.imgur.com/RKuWZoQ.jpg
Here are two high quality Tele pickguards for your next (and one after next) Tele building project.  I have always preferred the look of 5 hole guards, although if you disagree (and own a drill) these can obviously be converted to 9 holes.  As I also prefer to fix Tele neck pickups direct to the body and dislike seeing adjustment screws on the guard, I'd ordered these items without holes; again, you can drill these easily.
https://i.imgur.com/7Dbdofn.jpg
There is copper shielding on the rear of the brown tortoiseshell guard only, and both are quite matte in appearance.  No cracks, scratches, or other snarky defects.
https://i.imgur.com/mroADmO.jpg
  • FunkfingersFunkfingers Frets: 15780
    Your tort 'guard is four-ply. TFFT.  :)
  • dcgdcg Frets: 275
    Thank you!  You are of course 100% right.
    Is the diameter of the semi-circular cut-out where the control plate fits 32mm or 33 and a gnat's?
  • dcgdcg Frets: 275
    Both measure 32mm; I had these on Teles with both Fender and Gotoh control plates, and the fit was good.
    Glad to hear it.
    I am in the process of tarting up a Squier Standard series Telecaster. Its control plate is Metric, 33mm. I need to determine whether it would be cheaper to find a Squier-sized scratchplate or an Imperial control plate.
  • dcgdcg Frets: 275
    bump two great guards...
  • dcgdcg Frets: 275
    encore un bump...
  • dcgdcg Frets: 275
    Am I the only person who prefers 5 hole Tele pickguards?  Or is it just the colour of these particular 'guards?  I.E. these are still available bump...
  • dcgdcg Frets: 275
    bump...
  • lovestrat74lovestrat74 Frets: 2907
    Do you still have the torty guard?
  • dcgdcg Frets: 275
    Yes, I do!
