Hi folks,
Long time fingerpicker here, suddenly trying to get to grips with surf guitar. I have bought a few different picks, tried using them, lost a few of them in the process... I feel like all my muscle memory is gone, I keep hitting the wrong strings, and even when picking on a single string I just can't do it fast enough (yet?).
Do you have any tips to share? Any idea how steep the learning curve should be? Is it possible to get comfortable with and without a pick?
Please don't send videos, I'm after good old fashioned (read: last century) advice.
Cheers,
Jon
My picking with a pick skills improved a lot when I learnt a bit of mandolin as you do need a pick for that, otherwise it's too quiet. Maybe some beginners Mandolin picking drills might help as that tremolo style effect you use for playing tunes on one of those would be useful for Surf guitar lines I reckon. And also people learning the mandolin tend to be already proficient in playing something else, so the "beginners" exercises will be more geared towards people that have a certain amount of knowledge already
If you’re hitting wrong strings then you’re probably floating your hand. You need to maintain contact with something in order for your hand to have a reference point and know where it is. I was initially told to rest my hand on the bridge, and this is a good starting point.
go on YouTube and observe the right hand of some of your favourite players - I’d say there are four main approaches - rock (flat wrist, muting unwanted strings) bluegrass (pinky on guitar top) gypsy jazz (rest stroke, no anchor needed) George benson (rest stroke, backwards pick angle - see players like Paul Jackson Jr, Isiah Sharkey…)
have got me from 0% to 85% of where I wanted to be. Practice should take care of the other 15%.
Thank you so much, folks. Now, any tips for not losing picks? Perhaps I should keep one with me at all times?
My trading feedback: https://www.thefretboard.co.uk/discussion/210335/yorkie
for picks, I use V picks. Most regular, Snake and Screamer models, but I also have a colossus and insanity, which despite their size, and very comfortable picks to use
I bought over 100 different picks in various materials, bone, metal, plastic, acrylic etc etc after a year of trying every pick I could find, I settled on v-pick. They drop your skin, and don’t move. They sound great, super comfortable, and (in the models I use), zero flex. I can’t play with a bendy pick.
Here's the article:
https://fretboardanatomy.com/picking/
Update: After she read this article, Sheryl shared some further insight into her technique. She told me that she began picking this way because it “puts your pick at the same angle as your fingers would be if you played classical guitar,” and that she uses Fender Mediums for the same reason––because they’re “roughly the same texture and thickness as a fingernail.”
And although she adopted this technique “for tonal pursuit, speed came out of it.”
view I found it made my picking more precise and I could play faster and smoother .
I tried many different picks but ended up using basic Fender heavy or medium picks. It's worth a try. Good luck.
