WITHDRAWN :Orange Dual Terror with Orange 1x12 cab, separate Noisy Hammer 2X10 stereo/ mono Cab
In an attempt to thin the herd, here are some goodies up for sale. Everything is collection only from East Grinstead, West Sussex although I'm happy to consider part-way meets.
First up, an Orange Dual Terror complete with channel footswitch, gigbag and Orange PPC112 cab fitted with a Celestion V30. Everything in very good condition and full working order. The Dual Terror is actually pretty versatile and can be run at 7.5, 15 or 30 watts via the various toggle switches.
Price drop to just £400 for the lot.
Next up, a 2x10 cab from Noisy Hammer. This is fitted with a pair of WGS G10C speakers (75w each). It also has a Bright Onion connector box inside so can be run as a stereo cab (2 x 16ohm) or in mono (8 ohm load using both speakers) It can be run vertically or horizontally. It has rubber feet fitted for either orientation and also comes with separate short screw in "furniture" legs. It has a variety of rear panels giving you the option of running it as a closed cab, semi-open or with the Dumble style oval cutout.
In good overall condition with a couple of small nicks in the tolex which I can try and get pics of if needed. Dimensions (when upright on the rubber feet) are approx. 80cm tall, 40.5cm wide and 35cm at the deepest point. Now just
£300.
