Moltisanti
Frets: 1416
LOL 0
Wow! 0
Licence-exempt
The ranges 173.8 - 175 MHz and 863 - 865 MHz and 2400 - 2483.5 MHz can be used without a Licence subject to the requirements of The Wireless Telegraphy (Exemption) (Amendment) Regulations 2006. These ranges are also used by other low power equipment so can be subject to interference.
But the older units (like Shure PSM600) are 854.900 or 856.175 which is outside of this window, so are they now illegal ?
Why?
Canford’s take on it:
https://www.canford.co.uk/TechZone/Article/UKLegalRadioMicFrequencies
You should be aware, if your beautiful tones show up on either emergency services systems or interrupting someone with an exclusive licence you might just get a tap on the shoulder and a large basket of consequences.
https://www.ofcom.org.uk/spectrum/radio-equipment/shared/
I know someone who drove around for a significant length of time without a full driving licence and, as a result, with no valid insurance and I… I mean he… was never pulled.
Proof positive… of something.
Frequencies outside of those bands are specifically licenced for other uses. Some are digital TV transmission, some are for mobile network carriers, some for emergency services. There's a range for licenced walkie talkies. There's all sorts sitting across the radio spectrum.
In all likelihood, nobody is going to knock on your door, but the legality is that OFCOM can seize the radio equipment and anything it's connected to, and you can be liable for a pretty substantial fine.
If you want to know what's used for what purpose, OFCOM .have this nifty colour coded diagram of the whole spectrum, and you can click on each section for more detail on what it's used for.
https://static.ofcom.org.uk/static/spectrum/map.html
It does seem to suggest the licence-exempt section goes up beyond 865MHz to about 876, which I’ll need to work out.
