Best load box and IR loader solution
Hi all
I want to record with my pedals and heads into an IR loader so I can really dial in the amp and pedals in the mix.
I'd need a load box and an IR loader, what would you recommend? I'd like to use it live too. Is Captor x the best option?
I have an axefx 3, could I use that as the ir loader?
Ta
  • FarleyUKFarleyUK Frets: 2579
    I've also got an AFX3 I'm using kind of like this - I plug guitar in to the AFX3 input, out 3 (humbuster cable) into pedals then into the amp. Amp speaker out goes to the Captor X. Captor X right (dry signal) goes back to AFX3 via input 3.
    I'm using most of the FX in the AFX3, and also the cab block.
  • Suhr reactive load IR is the best I’ve tried for this.
  • I took the plunge with a suhr reactive load and celestion speaker mix plugin, sounds great and is so cool to experiment with speaker type, mic and placement in the DAW
